Gen 1: 2004-2005 Engine dies of while riding. - Kawasaki ZX-10R.net
post #1 of 7 Old 05-29-2011, 09:13 PM Thread Starter
Unhappy Engine dies of while riding.
Hi guys, have been encountering this problem while riding.
Engine will auto cut off while riding, and only at particular condition then it will cut off, temp around 85 degree, over uneven ground and i can only start the bike at neutral after it dies off.
Mod to my bike just an aftermarket exhaust.
Have anyone encounter with this?
vlRuS is offline
post #2 of 7 Old 05-29-2011, 09:19 PM
The Nam3less's Avatar
can you do a video?
'11 Black zx-10r | Tech-spec Tank pad | Akraprovic w/ link | Power Commander V | Auto tune | HID | 1/5 Insert | Driven Smog Plates | DMP integrated tail light | Vortex rear sets w/ new pressure switch | Puig dark smoke windscreen | BMC Air Filter | Cox Radiator Guard |
To Do List:
ECU reflash
Steering Damper revalved
The Nam3less is offline
post #3 of 7 Old 05-29-2011, 09:28 PM
zx racer's Avatar
check the side stand switch. sounds like its going bad.
05 ZX-10R SWB.
zx racer is offline
post #4 of 7 Old 05-29-2011, 10:06 PM
Gen2 Ripper
neverendingmods's Avatar
Cut the 2 wires going to the sidestand and splice them together. That will bypass the switch just make sure you remember to put your kick stand up before riding.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 7 Old 05-29-2011, 10:13 PM Thread Starter
Originally Posted by The Nam3less View Post
can you do a video?
It does not always happen, the frequency is quite low, so is quite diffcult for me to gauge when it will actually happen.
vlRuS is offline
post #6 of 7 Old 05-29-2011, 10:15 PM Thread Starter
Okay i will try to bypass it and see if it will to be the side stand switch
vlRuS is offline
post #7 of 7 Old 05-30-2011, 01:35 PM
Maddevill's Avatar
Red face I second that
Yeah the sidestand switch lives in grime/chain lube and vibration. When they start to go bad they will cause intermittant cut outs.
Maddevill is offline
06 engine dies, cycle the key and starts again dscort Performance and Tech 8 05-25-2010 06:55 PM
engine dies out when driving orange 10r The ZX-10R 43 09-15-2009 03:05 AM
Engine dies Sandblaster Performance and Tech 10 08-02-2009 12:31 PM
04 10R dies Bottlerocket Performance and Tech 16 08-15-2008 03:23 PM
Another 10 dies crispin The ZX-10R 18 01-13-2005 06:04 AM
