EMEGENCY: Tank leaking, NEED HELP ASAP - Kawasaki ZX-10R.net
post #1 of 45 Old 08-28-2008, 09:16 PM Thread Starter
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Im at WORK (again)... and my tank is leaking.
Fuel is LITERALLY dripping between the two parts i circled in the pic.
Should there be a rubber seal (o-ring) in between because I didnt find any.
I dont wanna ride it with a fuel leak BUT i also dont wanna leave it at work.
help pls.. thanks
-Lucky
Lucky10R is offline
post #2 of 45 Old 08-28-2008, 09:47 PM Thread Starter
Lucky10R's Avatar
Images: 19
anybody ?
Lucky10R is offline
post #3 of 45 Old 08-28-2008, 09:57 PM
10roller's Avatar
possible you didnt slide the fuel line all the way on? it does have a lil resistance whenever i attach mine.
10roller is offline
post #4 of 45 Old 08-28-2008, 10:49 PM
Rasavong's Avatar
I don't know how far you have to ride to get home, but for a quick fix tape it up and wrap it with some rags. Maybe that will be enough to get it home and asses the problem farther. Just an idea. Good luck though.
Rasavong is offline
post #5 of 45 Old 08-28-2008, 10:52 PM
bluedevil's Avatar
bluedevil is offline
post #6 of 45 Old 08-28-2008, 10:53 PM
bluedevil's Avatar
AT 40psi of pressure ..no not a good Idea fix it first or get a Tow Truck.
bloo
post #7 of 45 Old 08-28-2008, 11:10 PM
Daves Cycles's Avatar
If you can pull the line off without popping out the lock tab...you didn't get it on all the way.on the fix it or go get a pick up or trailer.Don't want to be a fireball going down the street!
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
post #8 of 45 Old 08-28-2008, 11:19 PM Thread Starter
Lucky10R's Avatar
Images: 19
hehehe.. i risked it... im at home right now...
but now the bike dies like its out of fuel...
it was running.. i rode it home... and now it starts, and then dies right away like out of gas...
what to do?
what to do?
Lucky10R is offline
post #9 of 45 Old 08-28-2008, 11:23 PM
bluedevil's Avatar
what to do?
what to do?
Geez, it's like talking to your Kids....check out Daves post right above yours for starters.
post #10 of 45 Old 08-28-2008, 11:27 PM Thread Starter
Lucky10R's Avatar
Images: 19
we're family here
Lucky10R is offline
Leaking near sprocket eightonezero Performance and Tech 9 12-20-2007 02:57 PM
Fork Leaking... Rock_Star The Out House 3 12-05-2007 05:17 PM
gpr stabilizer...leaking cmikej25 The ZX-10R 11 04-06-2007 10:56 PM
my 10 is leaking oil.... please help poohbear The ZX-10R 14 10-16-2006 10:01 PM
Fork Leaking? 05Ti10 Performance and Tech 6 07-16-2005 04:45 AM
