Electrical problem - Kawasaki ZX-10R.net
post #1 of 12 Old 12-13-2008, 09:13 PM Thread Starter
slav's Avatar
Send a message via AIM to slav
Electrical problem
Okay... Soldered a 06 tach plug onto my 05 harness which is not good because the heat that goes through the wires can shorten things out... Bike doesn't start and the only fuse that was blown was the ECU fuse. Does anyone have a 05 10 wiring diagram? Or anyone know how much damage may have been done? Also, how can I read the f1 light?
I unplugged the battery after all this as well as the ecu and other things.
please help!
slav is offline
post #2 of 12 Old 12-13-2008, 09:24 PM
Postwhore with an 04
bcm0018's Avatar
Is there a wiring diagram in the maintenance manual? I think it should and they are hosted on the sight and you can have a look.
bcm0018 is offline
post #3 of 12 Old 12-13-2008, 09:26 PM
I bleed Green!
whispering smith's Avatar
Images: 21
Good luck I've been thier. E-bay
Riseing Sun 2000 ZX-6R
Green 2004 ZX-6R 636
Every day is a new beginning.
www.stealeyconstruction.net
whispering smith is offline
post #4 of 12 Old 12-13-2008, 09:53 PM Thread Starter
slav's Avatar
What am I looking for on ebay? serviced manual?
slav is offline
post #5 of 12 Old 12-13-2008, 09:57 PM
luxurylows's Avatar
ECU shorted.. Gotta have the battery disconnected before you do any of that stuff.. .GOOD LUCK
IM THE GUY YOUR MOM WARNED YOU ABOUT!
luxurylows is offline
post #6 of 12 Old 12-13-2008, 10:40 PM Thread Starter
slav's Avatar
Do I need a new ECU then? The fuse blew when soldered.
slav is offline
post #7 of 12 Old 12-13-2008, 11:11 PM
Quick10's Avatar
Replace fuse and try again...If it fails again then further troubleshooting is required...Always disconnect power when performing electrical maintenance
Quick10 is offline
post #8 of 12 Old 12-13-2008, 11:49 PM Thread Starter
slav's Avatar
Changed the fuse and still nothing. I disconnected everything hoping to discharge any power and too out the fuses. Without the tach connected the bike should it turn on from what Remeber, would any miswiring do the same when it is connected?
slav is offline
post #9 of 12 Old 12-14-2008, 06:08 AM
Quick10's Avatar
Should run ok with the meter disconnected...I'm not sure what kind of problems you would have if it's miswired, it will depend on how you messed up...Check and make sure all wiring is good and check for shorts and short to ground if all is ok then you probably smoked the ECU
Quick10 is offline
post #10 of 12 Old 12-14-2008, 09:34 AM Thread Starter
slav's Avatar
Okay, had all fuses, computers, battery, and what ever plugs I could disconnect disconnected over night. plugged everything up this morning and both tachs worked... HELLO 06 tach! looks awesome.
slav is offline
Electrical/Lighting Help!!!! Blink180Wilhelm The ZX-10R 5 12-08-2008 05:38 PM
Serious Electrical Problem ajtmex Performance and Tech 11 12-25-2007 11:25 PM
Electrical Issue sonic397 Performance and Tech 8 09-16-2006 04:20 AM
Pain in the arse electrical problem Andy Performance and Tech 26 11-30-2005 05:05 PM
Electrical problem? Swoop Performance and Tech 3 10-04-2005 02:33 PM
