Electrical Issue - Kawasaki ZX-10R.net
post #1 of 9 Old 09-08-2006, 11:32 PM Thread Starter
sonic397's Avatar
Angry Electrical Issue
Hello all,
Just looking for advice. I own a 2005 Zx10r. Has one mod, where I went down a tooth up front. Otherwise, the bike is stock.
A few months ago, my tail light went out due to a blown fuse. Well, I replaced the fuse, and it was another month or so before it happened again. Well, the bike began to blow the tail light fuse over and over again to the point where i just left it off. Literally, the tail light fuse would blow the second I turned the ignition key. Anyway, I decided to ride to a friends house. When i went to leave, the bike was dead. The bike didn't and does not give any sign of life. I checked the battery with a voltmeter and it's fully charged. None of the fuses were blown, but I replaced all the fuses with new ones of the same rating anyway. Nothing. No LEDs, no tach, no noises. Nada.
I pulled fairings off and looked the bike over. There is no sign of burnt wires. Nothing abnormal. So I buttoned up the bike and found my warranty card. It's been sitting for like a month. The bike will be one year old in a couple of days.
05 Ninja ZX10r - Parting Out
sonic397 is offline
post #2 of 9 Old 09-08-2006, 11:39 PM
CountDokoo's Avatar
Check your main fuse. I remember there's a 30A main fuse somewhere in the front of the bike and NOT together with the fuse box.
CountDokoo is offline
post #3 of 9 Old 09-08-2006, 11:42 PM Thread Starter
sonic397's Avatar
Really?! Ok, kewl. I'm going to look. THX
sonic397 is offline
post #4 of 9 Old 09-08-2006, 11:59 PM
blackisfaster's Avatar
There is definately a main fuse (Not in fuse box). I have changed before on a ZX7R. Sorry I do not have a manual or knowledge of where it is on the 05 ZX10R. There is a 2004 Manual here:
http://www.shutupandplay.com/Brian/2004zx10r.pdf
Could check to see if electrical wiring is same for 05-06. Keep us posted. Peace
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
2006 ZX10R (Black)
blackisfaster is offline
post #5 of 9 Old 09-09-2006, 12:02 AM Thread Starter
sonic397's Avatar
Thanks for the link B, I was just looking for that.
sonic397 is offline
post #6 of 9 Old 09-09-2006, 08:45 AM
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
Think hard. Have you recently worked on the bike? There may be a pinched wire some where of a loose ground.
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
post #7 of 9 Old 09-09-2006, 09:16 AM
CountDokoo's Avatar
Yeah, replacing the fuse is only a short term solution to a long term problem. You should really source out the cause of the fuse blowing. Probably a bad short somewhere. Start with the tail light unit.
post #8 of 9 Old 09-09-2006, 01:05 PM Thread Starter
sonic397's Avatar
You guys are right. It would only be a short term fix. I was hoping to get it fixed under warranty, but who knows if they will even cover it.
sonic397 is offline
post #9 of 9 Old 09-16-2006, 04:20 AM Thread Starter
sonic397's Avatar
Hello all. Well I havn't figured out what is causing the tail light fuse to go out, but I did find a problem with the main 30a fuse. Turns out the outgoing wire on the 30a fuse relay (i think that's what it's called,) was loose. I unscrewed the already loose screw holding the outgoing positive cable. Turns out the screw was semi stripped or crossthreaded. I think the person who put my bike together f'd up a bit on that little unit. Anyway, I cleand up the thread and blew out the shavings and then used a some locktight on the screw and tighten the cable back up. Then replaced the 30a fuse. It fixed the previously dead bike.
So next week I'm just going to take the bike over to the dealer and have them fix whatever problem is causing the tail lamp fuse to keep blowing.
sonic397 is offline
Electrical Woes' FXSTCHIEF Performance and Tech 2 07-07-2006 03:17 PM
Electrical moron in need of simple help JXJeff Performance and Tech 6 02-13-2006 03:50 PM
Electrical problem? Swoop Performance and Tech 3 10-04-2005 02:33 PM
Electrical gremlins...help! RoninZX-10R Performance and Tech 10 09-25-2005 09:36 PM
Electrical system question. hayabusa57 The ZX-10R 1 06-05-2004 02:11 AM
