Gen 1: 2004-2005 Electrical HELP, Needed ASAP - Kawasaki ZX-10R.net
post #1 of 26 Old 05-06-2011, 05:35 PM Thread Starter
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Hey guy's,
I have an electrical issue going on.
This plug fried on me as you can see.
It's a 2005 Gen 1
What plug is it.
I'm trying to find it on the wiring schematic,
but I'm not sure what it is.
If I can figure out what it is, then I can look at
it on the diagram and re-wire it.
Help is needed ASAP please and thank you.
If you know for sure, please send a quick email
to my phone for quicker response :
[email protected]
Name:	Electrical Plug 001.jpg
ID:	147983   Click image for larger version
Name:	Electrical Plug 002.jpg
ID:	147984   Click image for larger version
Name:	Electrical Plug 003.jpg
ID:	147985   Click image for larger version
Name:	Electrical Plug 004.jpg
hellsrazor is offline
post #2 of 26 Old 05-06-2011, 05:58 PM
That looks like a connector that links all your power and earth connections, thats why you can see the little bridging links, this could of happened due to a bad connection at the connector or excessive current draw on that circuit, you would need to get hold of another connector and terminals and replace wire for wire so you dont get confussed. Hope this helps
ben20 is offline
post #3 of 26 Old 05-06-2011, 06:22 PM
was that thing hanging bare like that? it might have shorted itself out on the frame.
mityaz is offline
post #4 of 26 Old 05-06-2011, 11:11 PM Thread Starter
hellsrazor's Avatar
Images: 23
Yes, but I tried find it (Connector) on the schematic and cannot locate it.
So, I made my very own wiring diagram of it.
Next, I'm going to try and decipher the blade configuration to the wires
and map that into my schematic that I'm making.
Then see if I can make my own connection box according to my diagram.
I am also going to look for a wiring harness that reasonably priced,
and either splice it onto mine or replace the whole freakin thing.
I have had this problem another time outta this junction box before.
I had pulled the metal blade out and cleaned them and reinserted and all has been fine for a year or so.
Lastly, the only thing I can think of that pulls the most amps is the starter or fuel pump.
No noises or slow cranks, all has been well with it.
Anyone have a clue as to what caused this.
post #5 of 26 Old 05-06-2011, 11:13 PM Thread Starter
hellsrazor's Avatar
Images: 23
No, :headshake absolutely not.
It had the cap over it and was neatly wrapped in electrical tape.
After I cut the harness open from the last time it did this,
and cleaned and re-inserted the blades.
I wrapped it very good and neat.
post #6 of 26 Old 05-06-2011, 11:29 PM
NinjeR's Avatar
I don't know what it connects to, but tomorrow I will go out and look, but I'm thinking you MAY need a new wiring harness =X
NinjeR is offline
post #7 of 26 Old 05-06-2011, 11:34 PM Thread Starter
hellsrazor's Avatar
Images: 23
I am in the process of trying to find a bad harness
with that connector on it if possible.
Or if I can find a good harness for a reasonable price,
I'll just replace the whole harness.
Time to start Gen 1 thread shopping.
Who has a good or bad harness for sale ??
In the second picture, you see that #12 white wire that's
fried. I want to try and find out what it goes to.
Because it looks like the culprit of this problem.
I'm scoping the shit outta the schematic for it.
post #8 of 26 Old 05-07-2011, 12:01 AM
NinjeR's Avatar
MAYBE your buffness of your arms overwhelmed the circuitry of the bike and caused it to overload and short out?
That's why we've been telling you to find some sleeves...so stuff like this doesn't happen! =)
NinjeR is offline
post #9 of 26 Old 05-07-2011, 12:08 AM Thread Starter
hellsrazor's Avatar
Images: 23
This may be the connector in question.
Where is this F er on the schematic tho.
post #10 of 26 Old 05-07-2011, 12:22 AM
zxer7's Avatar
Kawasaki uses those connectors at the factory as a way of testing there wiring harnesses on the assembly line. They cause all sorts of problems after a while. I don't know how many of those things I have had to cut out of wiring harnesses because of corrosion etc. What you will have to do is just cut the connector out and solder all of the like wires together. All of the black yellow are grounds, brown are key on power, white are battery power.
Green ones are faster
'05 ZX10
'05 ZX10 Race Bike
'92 KX 500
zxer7 is offline
Gen 2 headlight needed asap jonrubiera Wanted: Buy or Trade 5 06-09-2011 09:09 PM
Need Help/Electrical/ASAP!!!!! chogue Performance and Tech 17 09-16-2010 02:23 PM
Bearings needed ASAP Playboy07 Wanted: Buy or Trade 2 09-07-2009 01:08 PM
Needed ASAP: 04/05 10R caliper bolt (2) TR-10 Wanted: Buy or Trade 1 03-14-2008 10:28 AM
Electrical help needed jessie_n_az Performance and Tech 11 10-05-2006 12:26 PM
