Ebc clutch plates swell alot? - Kawasaki ZX-10R.net
 3Likes
post #1 of 11 Old 07-24-2018, 07:28 AM Thread Starter
97grnrs's Avatar
I threw a set of ebc ck street fibers in the gen 4, from hot to cold I have to adjust my lever adjuster almost 3 full turns which is way more than any other clutch pack I've run, anyone know if there is a known swell issue with the ebc fibers? The clutch works great but there's no reason I should have to adjust the lever that far every ride.
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #2 of 11 Old 07-24-2018, 07:48 AM
Thats why everyone recommends stock plates. EBC plates are slightly above garbage. If the ebc plates even work, the consistency is horrible.
ddipaola likes this.
rcannon is offline
post #3 of 11 Old 07-24-2018, 08:58 AM Thread Starter
97grnrs's Avatar
They work fine but consistency isn't great. Oem plates don't seem to work well in the gen 4, I've changed out two sets already
97grnrs is offline
post #4 of 11 Old 07-24-2018, 07:38 PM
It makes sense. The clutch sits high, and its probably hard to get oil to it.
The oem plates are the best we have access to. What do yours look like when they come out? The secret to a decent clutch is getting oil on the plates. Unless they are wet, when they come out, you are screwed. Also, measuring the stack height when you put it together. Just match whatever the manual says. No more, no less. Ive had a hard time ever getting ebc plates into that range.
On every bike Ive had, Ive always removed the clutch basket and drilled it, for better airflow. Its easy to do, and its helped on every occasion.
If you google "drill clutck basket" you will see examples of what people did. I dont go crazy, like most of the pictures. Usually only 4-6 holes, evenly spaced.
Im not sure plates last much longer, but the clutch feels much better.
rcannon is offline
post #5 of 11 Old 07-25-2018, 05:25 AM Thread Starter
97grnrs's Avatar
Ya the oem plates are usually dry looking when removed, then they begin sticking causing bad downshifts, so far the ebc plates shift great but just drastically change freeplay after about 15min of riding, I guess i can live with that as long as it stays shifting smooth, it's a poor design by kawasaki on this bike.
97grnrs is offline
post #6 of 11 Old 07-25-2018, 09:34 AM
OEM only
primacarne is offline
post #7 of 11 Old 07-25-2018, 10:31 AM Thread Starter
97grnrs's Avatar
If you read the post you'll see oem doesn't work well on gen 4
97grnrs is offline
post #8 of 11 Old 07-25-2018, 05:35 PM Thread Starter
97grnrs's Avatar
Ebc is going to send a new set of fibers, they said there was a defective few sets circulating so hopefully that's all
rcannon likes this.
97grnrs is offline
post #9 of 11 Old 07-25-2018, 05:41 PM
bun1t's Avatar
I have an EBC SRC clutch with heavy duty springs. Quite a few trackdays and clutch up wheelies with no issues to date.
bun1t is offline
post #10 of 11 Old 07-25-2018, 08:34 PM Thread Starter
97grnrs's Avatar
Ya I went with the ck street fibers but I am running the hd springs
97grnrs is offline
Gen 1: What Clutch? EBC or TK? spirity Performance and Tech 10 10-09-2012 05:16 PM
EBC or Barnett Clutch Install Low9's The ZX-10R 6 03-21-2011 09:51 PM
EBC kewlar clutch question holav Performance and Tech 6 07-15-2008 04:04 AM
ebc clutch CrazeMS Performance and Tech 1 08-24-2006 10:31 AM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
