Dynojet's Ignition Modual - Kawasaki ZX-10R.net
post #1 of 15 Old 01-31-2005, 04:43 PM Thread Starter
ballsup's Avatar
i was just searching the web when i found this product at hard racing. It says that it directly connects to your pc through the expansion port. You can advance or retard your timing in each cyl. Also it allows you to increase your rev limiter. Does anyone have any more info on this?
ballsup is offline
post #2 of 15 Old 02-01-2005, 07:32 AM
Ryan Schnitz's Avatar
No more info until they are released...
Ryan Schnitz is offline
post #3 of 15 Old 02-01-2005, 07:43 AM
hummmmmmmmmmmmm.......
MAVRIK is offline
post #4 of 15 Old 02-01-2005, 09:05 AM
MIA Post Whore
miykl's Avatar
the expansion port is the same plug your quick shifter plugs into. Expect to have to pull the pins from the quickshifter plug and insert into the plug for the ignition module. Should be no big deal but just a heads up. Curious on pricing myself. slotting the pick up is free.
miykl is offline
post #5 of 15 Old 03-21-2005, 04:14 AM
You thinking about getting one?
sp500 is offline
post #6 of 15 Old 03-21-2005, 07:47 AM
I called a race shop this weekend and they said dynojet has been promising this thing forever and we wont see it for a while. SOmeone went to the Indy show and the dynojet techs said expect a late May time frame because they have only tested it on R1 motors.
BNninja is offline
post #7 of 15 Old 03-21-2005, 08:29 AM
MIA Post Whore
miykl's Avatar
Just advance your timing the way ivan did.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #8 of 15 Old 03-21-2005, 08:29 AM
I asked him about that and he said to wait because you can advance or retard indiviual coils which is better and will produce more power.
BNninja is offline
post #9 of 15 Old 03-21-2005, 09:02 AM
Hopefully this comes out understandable, according to the dyno i went to the revs cutout at about 12,500rpm, seeing that the tacho reads 13,000 as redline and cutout is about 13,500, realistically the motor should rev to 13,500 on the dyno, the ignition module allowing to raise by about 1000 would in a way bring it to what it should be in the first place if ya get my drift.
Any comments?
sp500 is offline
post #10 of 15 Old 03-21-2005, 09:13 AM
MIA Post Whore
miykl's Avatar
Any comments?
Not sure i understood what you meant, but I can tell you the tach on the bike is off nearly 1000 rpms on top. I have an aftermarket shift light for this reason.
2004 636 track
miykl is offline
Ignition Advancer cali10rider Performance and Tech 21 11-06-2004 02:08 PM
Ignition Advance Rotor Evil 10 The ZX-10R 10 05-08-2004 01:39 PM
