dynojet quickshifter question - Kawasaki ZX-10R.net
post #1 of 8 Old 06-05-2007, 09:28 PM Thread Starter
logmaster's Avatar
Getting ready to install. But I am confused as to the handlebar mounted switch.
Doesnt this automatically kill the fuel charge when the shift lever is raised?
What's the point of the bar mounted switch?
I can still upshift with clutch if I like, right?
logmaster is offline
post #2 of 8 Old 06-05-2007, 09:45 PM
Speed Freak
garth285's Avatar
the bar mounted switch is for like racing rules for no quick shifter, basically you put pressure on the shifter and then press the button and it will shit info gear.....kinda like a last resort to havin a quick shifter.
you have the regular linear shifter?
garth285 is offline
post #3 of 8 Old 06-05-2007, 10:19 PM Thread Starter
logmaster's Avatar
The box says " shift rod pressure tension sensor/ linear travel sensor/Bar mounted switch/shift rod"
So that's a "yes" I think.
post #4 of 8 Old 06-26-2007, 05:55 PM
inappropriate
hesaves0211's Avatar
Images: 67
whats you take on the device after you installed it?
you can override it and shift whenever right?
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #5 of 8 Old 06-26-2007, 07:36 PM Thread Starter
logmaster's Avatar
We installed it, but it's not workinmg yet. Just havent had time to mess with it. Yes, just shifting like normal for now.
post #6 of 8 Old 06-27-2007, 09:00 PM
Did you need to buy the push rod A or did you make the stock shift rod work?
06450F is offline
post #7 of 8 Old 06-27-2007, 09:13 PM Thread Starter
logmaster's Avatar
I have a new pushrod from DJ, but as I said, dont have things working yet.
This is not a slam on the shifter, the problem is me not working with it yet.
post #8 of 8 Old 06-27-2007, 09:17 PM
Okay but from what you can tell; is a new shift rod "neede" I just wonder because im about to buy my QS and wonder if I need to order a rod from DJ as well with it or save my $12
06450F is offline
Installing a Dynojet Quickshifter module. busaforhire Performance and Tech 79 06-22-2015 03:58 PM
Dynojet Quickshifter Black10R Parts, Gear and Accessories 14 12-24-2006 06:53 AM
dynojet quickshifter tank zx10r Vendors deals 1 11-20-2006 12:07 PM
Dynojet Quickshifter Black10R Performance and Tech 2 11-17-2006 12:44 PM
Installing a Dynojet Quickshifter module. busaforhire How To... 2 08-23-2005 09:18 AM
