Dyno Tuning Question - Kawasaki ZX-10R.net
post #1 of 16 Old 12-25-2008, 05:27 PM Thread Starter
edouble's Avatar
I can get a cheap dyno tune but he doesnt read A/F ratios. The tuner feels that if the bike is making power then A/F ratios must be right. What do you guys think about his theory? I am contemplating removing the secondaries but dont want to have to spend $300 with a tuner that reads A/F ratios versuses $100 with a guy that doesnt read A/F ratios.
Basically what I am asking is does a dyno tuner need to read A/F ratios to get a proper tune on my 06 10R that has the secondary flies pulled?
edouble is offline
post #2 of 16 Old 12-25-2008, 05:51 PM
ZX-10R_Sinner's Avatar
You can't tune a bike without A/F or carbon readings. Each bike will make different amounts of power, even two ZX-10R's same year off the showroom floor so that sounds absurd to me.
The first tuner I took my bike charged me 150 for baseline one day and tuning the next, and let me tell you that sucked. It was on an ATV dyno and the A/F was correct on his dyno, but extremely lean on a brand new 250i.
The second tuner I took it to had the tuning link and used that to tune it to an A/F ratio that I requested, costed me 237.xx but WELL worth it, couldn't believe the difference after the second tuning.
So basically, pull your flies and spend your money, I know it's a lot more but it's much better.
Haha oh yeah, after I told the tuner at Fenders, that I had gotten my bike tuned before him at Van Wall he gave me a pretty dirty look.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #3 of 16 Old 12-25-2008, 08:14 PM
Speed Freak
garth285's Avatar
yeah for sure bring it to someone who can read air fuel's and request a before and after to show that your air fuel is correct as well... W give people a before and after reading always to show what we do just because people want a visualization of the well worth money they spend.... dont concentrate on peak power as well. a good all around tune will make that puppy have awesome throttle response and great gas millage as well!!!
garth285 is offline
post #4 of 16 Old 12-25-2008, 09:01 PM Thread Starter
edouble's Avatar
Thnx garth285 I was hoping you were going to reply. What A/F ratio should I be seeking?
edouble is offline
post #5 of 16 Old 12-25-2008, 09:03 PM
Speed Freak
garth285's Avatar
for wide open throttle about 13:1 is good, but good tuners know that the bikes lean out when under ram air pressure... that is if you bring the bike up to those speeds... I had my buddy at the shop our dyno tuner tune it to about 12.4-12.5:1 on the dyno and it leaned out to 12.9-13:1 on the street which I think makes amazing power.
for cruising upwards of 14.5:1 are great for great gas millage and crisp throttle!
garth285 is offline
post #6 of 16 Old 12-25-2008, 09:40 PM
jcw
Just my 2 cents...
If he doesn't initally tune by A/F ratios, he won't know which way to go with the fuel mods to start.
You ASSUME you'll need more fuel when you pull the secondaries, but what about at different parts of the map? Is it rich or lean? No way to tell without an A/F monitor.
If you've ever tuned a bike, sometimes fuel map changes can result in some unexpected A/F results. Sometimes overshooting the target A/F whatever you are aiming for.
NOW, that said, after you get the A/F ratio roughed out, the very best tuners will go back and tune for best power. And yes, ignore the A/F readings for a while.
BTW, there really is NO optimal A/F ratio. 12.8:1 has traditionally been considered optimal for WOT, but some engines like to run leaner (up to 13:1), some richer (12.5:1). It depends on a lot of factors like cam timing, combustion chamber efficiency, etc. Yeah, and ram air can change things around. Only way to simulate that really is to get a wideband datalogger otherwise you're just guessing. And as mentioned above, 14.7:1 or leaner at cruise and light throttle for fuel economy.
Make sure you block off the exhaust air valve when taking the measurments too.
jcw is offline
post #7 of 16 Old 12-25-2008, 09:42 PM
Vince10R's Avatar
I usually tune to 12.8 and it will be around 13.0 in fifth gear on the logger with ram air. You can tune it for power without A/f but having the a/f will make the tune much quicker and easier. eventually they should tune it for peak power and then richen it up a bit to cover the ram air effect which will result in a lower dyno # but it will be right in fifth and sixth gear.
Vince10R is offline
post #8 of 16 Old 12-26-2008, 02:03 AM
zxdave's Avatar
def go get it tuned with the guy doin it by a/f ratios.....the bike will make better power and will be much much smoother, it will not have "holes" in the map that way and it will be much better for on/off thrttle changes as well
No chicken strips sold here......
zxdave is offline
post #9 of 16 Old 12-26-2008, 08:09 AM Thread Starter
edouble's Avatar
Hopefully I can find a tuner in my area that knows as much about this as you guys do!
BTW I have Ivans block-offs
edouble is offline
post #10 of 16 Old 12-26-2008, 08:31 AM
Postwhore with an 04
bcm0018's Avatar
Dyno tuning makes all the difference in the world. I used to have so many problems with my Mustang (Its N/A but has the works) and I finally took it to get dyno tuned by someone that is a renowned tuner and what a difference. I'm working on my bike over the winter but once I'm done I think I am going to make the drive to New York and have Ivan dyno tune it
bcm0018 is offline
Dyno tuning - How often? Andy_C Performance and Tech 1 08-03-2008 08:08 PM
Are There Any Good Dyno Tuning Shops In Arizona BAYBOI Performance and Tech 6 05-10-2008 10:00 PM
south jersey dyno tuning? hesaves0211 Regional Forums 10 02-10-2008 08:29 PM
dyno tuning price? coastiepete Performance and Tech 14 07-02-2007 09:31 AM
Custom dyno tuning fast1 The ZX-10R 6 01-27-2005 08:04 PM
