Dyno Shoot Out Q - Kawasaki ZX-10R.net
post #1 of 8 Old 07-19-2007, 03:57 PM Thread Starter
Murphdog's Avatar
Dyno Shoot Out Q
I am going to a Dyno Shoot out this weekend put on by a Harley dealership and they said they would let me enter my 10. The only problem is they said they have to beable to put an inductive clamp on a spark plug wire. Is there any way around that since I think our wires are little bit more concealed than a Harleys. Thanks Guys.
05' Ti ZX-10R, Cut down Yoshi, PCIII, Rifelman 1/5 Throttle, GPR Damper, BMC Race Filter, Champ Frame Sliders,GIpro ATRE, Pazzo Short Levers, Sato Rearsets, Pilot Powers, Driven Chain and Sprockets 520 +1 Rear -1 Front, Nissen Front Master Cylinder, Galfer Braided brake lines, Changed gauge cluster to red, Hot bodies undetail, Flush mount turn signals, But best Mod of all TRACK DAYS and Classes
Murphdog is offline
post #2 of 8 Old 07-19-2007, 04:12 PM
FAF
Rent this space
You should be able to pick up a tach signal by clamping over the ECU wires.
FAF is offline
post #3 of 8 Old 07-19-2007, 05:10 PM Thread Starter
Murphdog's Avatar
Right now I have a LM-1 Wide band O2 on there with an Aux input that reads RPMs off of a Injector wire. I just tapped into it and ran it under my Pass seat. Would that work? If so does the other end of the wire have to be connected to something?
Murphdog is offline
post #4 of 8 Old 07-19-2007, 05:23 PM
FAF
Rent this space
I dont think that will work, most of the clamping pickups just measure pulsewaves through a wire, you wont have any pulses there unless they directly connect it to a pickup , which they probably dont have.
I dont know off hand what color the tach feed wire is from the ecu but they should just clamp over that.
On the dyno's we use occasionally we just clamp over the whole ECU harness and pick up the feed that way, sometimes you will pickup 2 feeds for the coils and then you just recalibrate the software to display half the reading.
FAF is offline
post #5 of 8 Old 07-19-2007, 05:27 PM Thread Starter
Murphdog's Avatar
Thanks for the info. I will look into the wiring for the tach and go from there. Thanks again.
Murphdog is offline
post #6 of 8 Old 07-19-2007, 06:47 PM
FAF
Rent this space
If you use one of the wires from either 9 or 15 you will get a signal at the ECU , one is the cam sensor and the other is the crank trigger , you should be able to clamp over one of these two.
FAF is offline
post #7 of 8 Old 07-19-2007, 06:48 PM
FAF
Rent this space
It looks like Yellow/Red or Yellow/Black.
FAF is offline
post #8 of 8 Old 07-20-2007, 10:18 AM Thread Starter
Murphdog's Avatar
Thanks FAF. That really helps me out.
Murphdog is offline
Shoot Out FAF The Out House 8 01-12-2007 10:40 PM
Shoot them their birds boy! sabersaw30 Pictures and Videos 6 04-28-2005 10:33 AM
Shoot em up... R1GSXRKILLER Pictures and Videos 1 12-13-2004 04:57 PM
West Coast Dyno Shoot-out - 159.7 & 545.1 k bryant The ZX-10R 12 07-20-2004 04:06 PM
First 04 shoot out at daytona. CDRacingZX6R Archives 20 12-11-2003 03:32 AM
