Dyno sheets of Kawi exhaust race cam inside - Kawasaki ZX-10R.net
post #1 of 16 Old 08-23-2006, 11:28 AM Thread Starter
Speed Freak
garth285's Avatar
Hey guys, heres the dyno sheets of a before and after of having jsut the kawi intake and stock exhauyst versus both race cams. The exhaust cam is JUNK! its about .5mm smaller lift and 8-10 less in duration.
Heres the dyno sheet.
I forgot to correct one thing on here I am running stock rims on 17/39 stock gearing with a 530 ERV3 chain.
Before:
After:
peak power before 147 after 140. and a dynojet # would be around 173hp vs 167.
garth285 is offline
post #2 of 16 Old 08-23-2006, 11:31 AM
Post Whore
1killer1liter's Avatar
Images: 11
Why are you running a 530 chain?
1killer1liter is offline
post #3 of 16 Old 08-23-2006, 06:42 PM Thread Starter
Speed Freak
garth285's Avatar
sorry typo 520*
garth285 is offline
post #4 of 16 Old 08-23-2006, 06:59 PM
when you installed the cam did you also use the new valve springs that go with it and did you degree cam
steedaboy is offline
post #5 of 16 Old 08-23-2006, 07:33 PM Thread Starter
Speed Freak
garth285's Avatar
didnt use valve springs......not needed for the cams and I degreed them to 107.5/103
garth285 is offline
post #6 of 16 Old 08-23-2006, 07:38 PM
we warned you... you just thought we were holding out on you didnt you?? LOL
deezuhl is offline
post #7 of 16 Old 08-23-2006, 07:43 PM
Ruthless Racing's Avatar
Images: 9
My motor has a milled head, valve job, and degreed stock cams. The guy that did my motor also did one with same mods as mine plus Star Racing headwork and Kawi intake cam and my bike made 7-8 more HP in the midrange and both bikes ended up with 173HP to the rear.
Ruthless Racing is offline
post #8 of 16 Old 08-23-2006, 07:52 PM
colinmitchell111's Avatar
Send a message via AIM to colinmitchell111
So why would they even make the exhaust cam if it hurts performance?
colinmitchell111 is offline
post #9 of 16 Old 08-23-2006, 08:09 PM
Shorty's Performance
madnessracing's Avatar
sometimes it works if you use it with the right combination but most of the times it doesnt..
madnessracing is offline
post #10 of 16 Old 08-23-2006, 08:15 PM
ill garantee if degreed properly to their race specs with their combo it makes power down low and mid..
deezuhl is offline
Kawi Race Exhaust Camshaft.....anyone use it? garth285 Performance and Tech 63 09-12-2006 08:40 PM
Twin Turbo Dyno Sheets steve p Performance and Tech 20 08-15-2006 09:58 PM
Does anyone here have the Kawi race ECU??? garth285 Performance and Tech 15 07-28-2006 07:22 PM
Custom Mapping Dyno Sheets DB's ZX10R Performance and Tech 4 08-15-2005 09:43 PM
Kawi Race box?? silverbullet1000 Performance and Tech 9 07-18-2005 02:12 AM
