Dyno #'s seam low.??? - Kawasaki ZX-10R.net
post #1 of 7 Old 05-10-2007, 01:59 AM Thread Starter
bugman53's Avatar
I had my 05 10 dynoed at a local shop. It was done on a 250I with tuning link.
It took 1.5hrs on the dyno and this guy took his time and really did a good job.
Kawasaki Race intake Cam 107-103.5
Head Gasket .50
Some basic head work. Cleaned up ports, blended valve seats ect.
Power commander
Akrapovic slip on
Exhaust butterfly valve removed
-2 front sprocket
It was at 150 before the tune and ended up at 157 after the tune
I will post graphs Tomaro. That just seams low to me it should be around 165-170 I would think.
On a positive note the curves look great for 4K to 12 K there is less than 10ft lbs of torque deviation. The curve is FLAT. Peaking around 10.5
Hp makes a perfect line and pulls to rev limiter and never falls off. No dips at all. Looks like the line was drawn with a ruler. It looks like I can rev it more and make more power.
One question with the -2 sprocket throw off the reading? It has no Speedo healer.When he was doing 4th gear pulls It toped out at 172 on the computer screen that is not even close to actual speed but it might read that on the Speedo.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #2 of 7 Old 05-10-2007, 10:41 AM
FAF
Rent this space
Perfect lines can be achieved by smoothing the aspect ratios on the graph , if you scaled with smaller increments you will see a whole different picture, but all in all , it sounds like you generated "real world" numbers.
FAF is offline
post #3 of 7 Old 05-10-2007, 11:05 AM
Speed Freak
garth285's Avatar
the sprocket could throw the dyno off a bit, dynojet dynos are more of an accelerometer so it measures how fast it spins a drum. kinda gotta stick to the numbers are just numbers kinda thing.
garth285 is offline
post #4 of 7 Old 05-10-2007, 02:00 PM Thread Starter
bugman53's Avatar
Greeensboro NC
bugman53 is offline
post #5 of 7 Old 05-10-2007, 09:43 PM Thread Starter
bugman53's Avatar
So what do the graphs look like in comparison to other 10's .
Greeensboro NC
bugman53 is offline
post #6 of 7 Old 05-11-2007, 12:12 AM
ducatiryder89's Avatar
Images: 21
Look at the temp. That could possibly play a role in lower HP numbers. But I don't think with your mods you would have 165-170 wheel HP. Realistic stock wheel HP numbers are 145-150. 15-20 wheel HP with minor headwork and tuning is a ton. I know guys with full headwork, extensive A\F and Ignition tuning, full system, ect.... getting 165-170 wheel HP. I think with cooler temps you might be in the 158-160 wheel HP. I dynoed stock [email protected] with 73.7ft.\lbs. But thats just what I've experienced.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #7 of 7 Old 05-11-2007, 10:55 AM
My stock 06 made 160. After intake cam, head gasket, ti force exh. and mapping I made 175rwhp. Had the same cam timing #'s as you.
11outa10 is offline
First Dyno Run LoCoZx10R The ZX-10R 24 10-21-2006 10:28 AM
dyno run ninja2k5 Performance and Tech 18 05-19-2006 06:49 PM
Awesome first rally and dyno run share dyno numbers No-Mo The ZX-10R 36 05-19-2006 05:53 PM
DYNO #'s are in!!! RickRoush03 The Out House 20 10-21-2005 10:56 AM
Went to the dyno! KDW Performance and Tech 10 09-22-2005 06:39 PM
