Dyno results - Kawasaki ZX-10R.net
post #1 of 20 Old 02-02-2005, 07:18 PM Thread Starter
Post Whore
Older Guy's Avatar
Dyno results
took the bike in today...bitched about the poor tip in throttle response...he installed a K & N air cleaner - said the stock filter was clogged up - put it on the dyno and said the mapping wasn't right and corrected it...claims my HP went from 144 to 157 - with just Akra slip on and the filter. Jack's bike was dyno'd at 164.
Will try and get the chart and post it...
Older Guy is offline
post #2 of 20 Old 02-02-2005, 08:31 PM
MIA Post Whore
miykl's Avatar
157 with filter, slip on, and custom map sounds about right. When was the 144 done? same day?
miykl is offline
post #3 of 20 Old 02-02-2005, 08:53 PM
nice numbers
black10r_n_nc is offline
post #4 of 20 Old 02-02-2005, 08:54 PM Thread Starter
Post Whore
Older Guy's Avatar
Yes, same day - he said map was messed up and way too rich with the clogged filter...
post #5 of 20 Old 02-03-2005, 12:00 PM
It wasn't the honda, kawai dealership in monterey was it? That place does wonders with mapping. My buddies 929 dynoed 118 when he took it in. After a custom map it did 138hp
He could not believe how much faster it was. My friends 02 gsxr 750 still pulled away from him the same after he took it in as it did before though.
badass1000 is offline
post #6 of 20 Old 02-04-2005, 10:11 PM Thread Starter
Post Whore
Older Guy's Avatar
I have dyno chart I could post if I knew how...they are in jpeg format...I can e-mail to someone who knows how to post images...or give me directions.
post #7 of 20 Old 02-04-2005, 10:16 PM
Pretty good end results but 144 seems awfully low just curious, everything was done the same day?
Frankyoz is offline
post #8 of 20 Old 02-04-2005, 10:30 PM Thread Starter
Post Whore
Older Guy's Avatar
post #9 of 20 Old 02-04-2005, 10:32 PM Thread Starter
Post Whore
Older Guy's Avatar
post #10 of 20 Old 02-04-2005, 10:35 PM Thread Starter
Post Whore
Older Guy's Avatar
Well got a custom map for the 10. They found it running very rich off idle and that's why I have been having abrupt throttle changes when going from off throttle to on throttle. It is much more linear now. He said mapping doesn't change much below a certain rpm....put in the BMC filter...stock filter was clogged after 11,000 miles...will make sure it is serviced every 3,000 miles at the same time I get the oil changed...yes, has more power and much more linear delivery....should get better milage too...they charged me $300 and took about 5 hours of dyno time...(PS - their normal price is $350, but I spent $2,600 2 months ago and he agreed to give me a $50 discount)...
Dyno after mods DustinR Performance and Tech 16 01-15-2005 06:13 PM
Any other slip-on dyno results? Without a PCIII though? STREETFIGHTER50 Performance and Tech 12 10-25-2004 01:32 AM
Finally dyno results kwakman Performance and Tech 1 10-21-2004 07:24 AM
Sato S/O Review and Dyno Results TAFB The ZX-10R 55 10-14-2004 07:44 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
