Dyno jet quick shifter - Kawasaki ZX-10R.net
post #1 of 7 Old 05-08-2013, 11:48 AM Thread Starter
kawboy69's Avatar
I have a 2011 ZX-10 and I am wondering why I need a SFM along with the pc5 to make the quick shifter.
Could someone please explain.
Thanks
It's better to shut up and appear stupid than open your mouth and remove all doubt.
kawboy69 is offline
post #2 of 7 Old 05-08-2013, 11:52 AM
SkyDork's Avatar
Because the QS interrupts the fuel delivery to unload the transmission to make the shift. The PC alone only controls the lower 4 injectors. You need another unit that controls the upper injectors to shut off all the fuel to make the shift.
#WordCrimes
SkyDork is offline
post #3 of 7 Old 05-08-2013, 12:08 PM Thread Starter
kawboy69's Avatar
Thank you.
kawboy69 is offline
post #4 of 7 Old 05-08-2013, 08:00 PM
skidooboy's Avatar
or you can go with a Bazzaz qs4 stand alone unit, which uses a better qs switch, and cuts the ignition v.s fuel. and it is programmable for all gears, when you want different cuts for different gears. the higher the gear the less cut you need to make the shift.
Ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #5 of 7 Old 05-08-2013, 08:07 PM
OxyG3nE's Avatar
im using the bazzaz and it work so welll
OxyG3nE is offline
post #6 of 7 Old 05-08-2013, 08:21 PM
SkyDork's Avatar
Yeah, I'm using the QS4USB unit from Bazzaz as well. Nothing but good things to say about it.
#WordCrimes
SkyDork is offline
post #7 of 7 Old 05-08-2013, 08:32 PM
WildB302's Avatar
Or be a bad ass like me and foot shift just as fast! Lol GP of course.
08 race cam(108/103), 08 retainers, polished exhaust ports, milled head(.010), .45HG, short velocity stacks, removed sec, bmc filter, full Akra Evo cut 5in, pc3., ign module w/rev xtend to 13,500., Lots of 520 sprckts, vortex rearsets (gp shift), pazzo levers, galfer lines, ZX14 calipers, shorai batt, carbon frnt fender, gpr, puig screen, gilles chain adjs., 1/5 throttle, Kleen air mod, Braking rotors, O.Z. wheels, 403lbs full fuel
http://www.youtube.com/user/TheWildb302/videos
WildB302 is offline
Dyno Jet Quick-Shifter WhiteZX10R The ZX-10R 46 03-04-2010 12:13 PM
??Dyno jet Quick shifter W/ Race ECU?? Ninja187 Performance and Tech 0 06-30-2009 11:27 AM
Help with Dyno Jet Quick Shifter colinmitchell111 Performance and Tech 13 09-19-2006 07:22 PM
Quick shifter by dyno jet 10 speed Performance and Tech 2 02-01-2006 08:48 PM
Dyno jet quick shifter bluebyyouz Performance and Tech 1 08-15-2005 11:41 PM
