Gen 4: 2011-2015 Dyno Day - Kawasaki ZX-10R.net
post #1 of 13 Old 10-31-2016, 02:02 AM Thread Starter
Dyno Day
So I was all hyped to go throw the bike on the dyno and see what my numbers are before I do my last few mods that I'm hoping to gain a good chunk of hp and tq out of. I get to the shop it goes on the dyno and ... the first question after they finished was does my bike rev out on the road ?... i was like yeah it does I get a little fast jump from 8k to 13k before it starts to bounce off rev. So I ask why he asks... there response was because your bikes slipping. So my cocky kind of annoyed self goes well did you mess with the traction control ? Because I know some bikes have issues on certain dynos with certain dyno mechanics doing it. They say yes we tried messing with it. They then told me that it could me my clutch slipping.
So my question I guess is has anyone dyno'd they gen 4 and had this issue or have had your clutch slip on the dyno and it put out way less then stock numbers ? Should I just start off with replacing my springs or just go and do plates and springs all at once?
Jlefevre1122 is offline
post #2 of 13 Old 10-31-2016, 06:40 AM
dricked's Avatar
Pull the clutch and asses what you'll need or if that's even the issue before ordering anything. It takes 10min and you won't waste any money. A slipping clutch usually means plates but measure your springs as well.
dricked is offline
post #3 of 13 Old 10-31-2016, 06:44 AM Thread Starter
That's my weekend plan I was honestly hoping someone was just gonna be like yeah sometimes it happens with certain dyno because of traction control
post #4 of 13 Old 10-31-2016, 06:49 AM
SkyDork's Avatar
If the freeplay isn't set right on the clutch lever, you'll wear out the plates prematurely. The G4 is particularly sensitive to this and the freeplay will change slightly when the clutch is hot versus cold. If you don't have enough freeplay in the lever adjustment to account for this, then the clutch will never fully engage and it will struggle to transmit that much power which leads to the wear. If it's slipping, then the plates are worn and will need replacing. As Dricked mentioned, the springs could be worn as well and should be checked while changing them out.
It's an easy job, especially on the G4 with the clutch well above the oil sump.
#WordCrimes
SkyDork is offline
post #5 of 13 Old 10-31-2016, 06:52 AM Thread Starter
Yeah I checked the manual and it's not a difficult job i was honestly thinking of getting a Barnett carbon fiber clutch plate kit for 175 and change everything all at once
post #6 of 13 Old 10-31-2016, 07:08 AM
dricked's Avatar
Make sure you set the freeplay with the bike hot or while your riding. Mine changed quite a bit after it got warmed up and if I'd had it adjusted properly cold there'd have been 0 freeplay when hot and ruined my clutch.
dricked is offline
post #7 of 13 Old 10-31-2016, 02:42 PM Thread Starter
I'll definitely keep that in mind and make sure I do that
post #8 of 13 Old 10-31-2016, 02:56 PM
ShawnG's Avatar
how many miles? probably is the clutch though... the 4th gen clutch is garbage. If its not slipping now it definitely will be soon so i would just call cycle concepts and get there drag pack clutch. I wouldn't waste your money on anything else, they know what works best for the 4th gens. you can get stiffer springs also through them and it definitely holds now on mine.
ShawnG is offline
post #9 of 13 Old 10-31-2016, 04:13 PM Thread Starter
Just over 14k miles now and I'll definitely look into them
post #10 of 13 Old 10-31-2016, 08:26 PM
dricked's Avatar
I got two race seasons on mine and it was still easily usable. I replaced it with another oem and had no issues again this season. 5000km of race use and I could have used one clutch.
dricked is offline
8/23/13 Gen2 Dyno Day naTion Pictures and Videos 0 08-23-2013 10:14 PM
Aussie Dyno Day Dave The ZX-10R 22 11-06-2008 02:54 PM
dyno day bigzx10 Performance and Tech 9 08-25-2007 02:10 AM
A day down at the Dyno. Molly Performance and Tech 8 03-17-2007 07:02 PM
All Day dyno for $75 BNninja The ZX-10R 10 03-25-2005 07:46 AM
