Dumb Dumb Dumb - Kawasaki ZX-10R.net
post #1 of 2 Old 06-12-2007, 07:57 AM Thread Starter
redline659's Avatar
Dumb Dumb Dumb
OK soooooo I have a small problem, Got the bike done late last night, loaded it into the truck and now I am at work. "Work is close to the drag strip" FORGOT my owners manual, I need to set my shift light and I dont know how ,,,,,,,,,,, I know its dumb, a little help before I leave work would be great........ First trip out to the strip on the new hot rod 06 zx10.
redline659 is offline
post #2 of 2 Old 06-12-2007, 09:56 AM
superman10r's Avatar
*Push the MODE and RESET button simultaneously for more than 2 seconds. The previous shift-up engine speed setting will be displayed in the tachometer gauge.
*To change the shift-up indicator light mode, push the MODE button and the shift-up indicator light will shift between light off, flash, lighton (bright), and light on (dim). The shift-up engine speed can only be adjusted when the light is on.
*To adjust the shift-up engine speed, press the RESET button and the shift-up engine speed timing advances in 50 r/min (rpm) increments up to 13000 r/min (rpm) is reached while advancing, the increments reverse.
* To complete the adjustment. push the MODE button and RESET button simultaneously for more than two seconds. The tachometer now operates normally.
Hope this helps goood luck.
2006 ZX-10R Black "Snake Eyes"
starrotors.com 6000k h.i.d. kit, T-rex frame sliders, Nissin Calipers, Galfer HH pads, Galfer SS brake lines, Puig DB windscreen, Micron exhaust, Powerbronze carbon fiber, Driven grips, Pazzo levers, and Gilles rearsets.
Note: Pray for peace, train for war. There can be no freedom without sacrifice.
"remember pain is temporary but quitting last forever. Feed the warrior"
superman10r is offline
OK dumb new guy ? jezzolo The Out House 18 04-07-2007 12:11 AM
what a dumb ..... cain772 Pictures and Videos 2 11-25-2006 08:33 PM
Probably a dumb question, but... phastone Performance and Tech 6 08-29-2006 11:24 PM
Dumb A** In-law soida The Out House 24 04-21-2006 11:49 PM
who's the dumb ass cain772 The ZX-10R 36 03-11-2005 09:09 AM
