Dry clutch/mods/drag use - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By badassjake
post #1 of 6 Old 03-20-2019, 04:27 PM Thread Starter
Hello, I recently rebuilt an 06zx10R. When I tore the bike down I noticed the clutch pack was dry. Thought it odd at the time as I race dirt bikes and the clutches always come out wet. I did some reading on this clutch and most want to use the 04/05 slipper disc and get the stack height correct. Some even add GSXR intake valve spring X3.
After installing clutches in motor (WET) and riding a few times around the block I noticed the clutch was grabby. Took it apart and the clutches were dry again. At this point I am thinking my oil is low, I missed some oil port to lube them or other. Any advice appreciated.
While I was in the basket again, I welded the 3 rivets as I saw a similar post on doing this mod.
The total weight of rider and bike is 700lbs and will be used for drag racing 1/8 mile. If anyone has a good link to a lockup+ spacer plate or other means to have this clutch hold up, please advise. I don't have lots of cash for a slipper, so I need something <500 to set me straight. Whether it be specific clutches + springs or other.
Thanks in advance.
ID:	421533   Click image for larger version
ID:	421535   Click image for larger version
rocksalt is offline
post #2 of 6 Old 03-20-2019, 09:46 PM
badassjake's Avatar
There is a mod to drilling pilot holes in the inner basket and grouving the clutch rod to allow more oil to flow to the basket. Google Zx12 clutch oil mod.
michael4012 likes this.
badassjake is offline
post #3 of 6 Old 03-20-2019, 11:14 PM
michael4012's Avatar
Agree with above its a good modification, cheap and simple which cures the issue
michael4012 is offline
post #4 of 6 Old 03-21-2019, 01:39 AM
theatiss's Avatar
Have u done it to your bike?
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #5 of 6 Old 03-21-2019, 02:38 PM
Agree with above its a good modification, cheap and simple which cures the issue <a href="https://zx-10r.net/forum/images/ZX-10R_net_2015/smilies/tango_face_grin.png" border="0" alt="" title="Big Grin" >:-)</a>
Yes there's no reason not to it's all positive costs nothing and takes 20 minutes or so if the clutch is out already.
post #6 of 6 Old 03-21-2019, 02:49 PM Thread Starter
I agree 100%. However, why is the stock clutch dry? This seems to be common issue. Are they supposed to be wet clutches or designed to be basically a dry system? I see so many posts on removing clutches, oil them and re-install. This seems like insanity... How would this even help for more than 15 minutes?!?
rocksalt is offline
Gen 2: New to forum ZX10 Clutch Kit DRAG use Question Boostedgreddy Performance and Tech 19 05-22-2016 12:50 AM
Slipper clutch, How do i use it, do I need to use it, is it all just hype?? b4tn Performance and Tech 1 08-09-2008 06:45 AM
Dry clutch edouble Performance and Tech 6 08-01-2007 02:39 PM
Dry clutch plates?? appocalypse Performance and Tech 7 09-09-2006 11:18 PM
