dropping a cylinder. - Kawasaki ZX-10R.net
post #1 of 14 Old 03-26-2012, 09:34 AM Thread Starter
Gnar0810R's Avatar
I have a Gen 3 with 24,000 miles. Bazzaz ZFi, TRE, Block offs. And starting a few weeks ago I would start it up and it would be running on 3 cylinders and it would be throwing raw fuel out the pipe . And after a while it would run on all 4 cylinders. it keeps going back and forth. I pulled the plugs and it looked like the #1 plug was fouled so I replaced it and flushed my tank. Airfilter was clean so no worries there. It ran good for a while and then it dropped the #1 cyl again. I switched the #1 and #4 coil sticks to see if could have been the coil. It didnt do it again for 2 weeks but then it dropped the #1 cyl again. It seems to do it on start up more then any other time. And its intermittent So Im thinking my #1 injector might be stickin open when my fuel system primes. Any ideas?
Gnar0810R is offline
post #2 of 14 Old 03-26-2012, 09:43 AM
Does not drive into smoke
El Zilcho's Avatar
If there is fuel in the exhaust, then the injector probably does work. I suspect the problem is somewhere else, especially since it did work for a while after you replaced the plug.
El Zilcho is offline
post #3 of 14 Old 03-26-2012, 09:44 AM
cyclepuck's Avatar
Could also be the bazzaz acting up. Disconnect and ride for awhile see if it does it again.
cyclepuck is offline
post #4 of 14 Old 03-26-2012, 04:27 PM Thread Starter
Gnar0810R's Avatar
Im thinking of removing the injectors and ultrasonic cleaning them. I will also remove the Bazzaz at some point. I just want to do one thing at a time so I can try to pinpoint the problem with out throwing a ton of money at it.
post #5 of 14 Old 03-26-2012, 06:30 PM
Post Whore
-Op-'s Avatar
thats a very smart and wise option to do, and removing the Bazzaz is the best option to follow that, since its really the only thing electrically non-stock dealing with fuel
-Op- is offline
post #6 of 14 Old 03-26-2012, 07:08 PM
Kawawog's Avatar
Send a message via MSN to Kawawog
+1 on removing the bazzaz first.. When I started having problems with my gen 3 dropping a cylinder a couple months back I disconnected the PCV and bam it was running sweet again
Kawawog is offline
post #7 of 14 Old 03-26-2012, 07:12 PM
Boomer Sooner!
Bpcullen's Avatar
How do you know it was dropping a cylinder and only running 3? ( I'm just trying to learn as much as possible )
Boomer Sooner!!!
Bpcullen is offline
post #8 of 14 Old 03-26-2012, 07:14 PM
El Zilcho's Avatar
One header pipe cooler than others. Spray some water on the headers and see if it evaporates equally fast. Or you can use an infrared thermometer.
post #9 of 14 Old 03-26-2012, 07:17 PM
Post Whore
-Op-'s Avatar
or the blistered hand favorite of touch it lol. Please dont do this!!
-Op- is offline
post #10 of 14 Old 03-26-2012, 07:17 PM
Boomer Sooner!
Bpcullen's Avatar
Sweet, thanks.
Boomer Sooner!!!
Bpcullen is offline
Gen 4: Help! Losing power dropping cylinder intermittently speedy14 Performance and Tech 332 03-06-2016 09:39 AM
Dropping the Engine bikeliker The ZX-10R 26 01-25-2010 07:09 AM
Dropping Revs Weasel1976 The ZX-10R 8 06-30-2009 12:45 PM
Dropping your front end? ninjasuz Performance and Tech 29 07-05-2007 12:00 AM
ducati dropping out of AMASBK madnessracing Race and Stunt 15 09-14-2006 02:14 PM
