Dropped a screw. Damnit. - Kawasaki ZX-10R.net
post #1 of 10 Old 10-27-2008, 04:18 PM Thread Starter
curiousmike's Avatar
I thought I'd try to save 5 minutes changing my air filter over the week-end by not completely removing the tank.
I propped the front of the tank up with a few rags, and with a 90' screwdriver, was able to get the airbox top off, and inserted the new air filter element.
Going to put back in the left-rear screw, it was a tight fit and... drop.
The screw fell into the bike... somewhere.
Shit.
So I go ahead and take the tank off, and start looking. And looking.
I pull the bike into the middle of my street, angle it so I have maximum Sun angle.
Use my brightest flash light.
Go fishing with one of those magnetized telescoping sticks.
I took off my front-sprocket cover, thinking maybe it'd worked it's way into there.
I can't freaking find it. It did not fall on the garage floor.
So, it's in a crevasse, somewhere.
I'm pretty resolved to just let it sit where ever it is, order a new screw, and chalk it up to being an idiot trying to save time.
But before I button it back up with the hideaway, the thought of it somehow sneaking into my front sprocket and locking up the drivetrain gives me pause.
Suggestions or ideas?
2005 Titanium, Hyperpro RSC, Sato Slip On, Champ Frame/Swingarm sliders
curiousmike is offline
post #2 of 10 Old 10-27-2008, 04:26 PM
drkramm's Avatar
i did that with a steering damper bolt .. so i painted a bolt red and dropped it where i dropped the other one .. lost that one too tried it again and then found all 3
as long as you have your sprocket cover on i wouldn't worry about it
"Once you've tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return."
drkramm is offline
post #3 of 10 Old 10-28-2008, 12:40 PM
lol your method is awsome!
fourdoorracer is offline
post #4 of 10 Old 10-28-2008, 02:03 PM
Beginner w/29k miles :o)
minebymistake's Avatar
Send a message via MSN to minebymistake Send a message via Yahoo to minebymistake
3rd times a charm
Nancy is not looking backwards for very long, shes moving forward opening new doors & doing new things because she's curious & curiosity keeps leading her down new paths! if you dont like it
minebymistake is offline
post #5 of 10 Old 10-29-2008, 02:41 PM
TALLPAUL's Avatar
Shit.
Ha I did the exact same thing a while ago. I pulled the fairings off, pulled the entire airbox out, front sprocket cover, even had a tube taped to the end of my vaccum cleaner and tried blowing it with an air nozzle and couldn't find it. I finally put it together and rode it. One ride through town and the screw was sitting in my belly pan I didn't save much time in the end either
I get paid for this ?!?
TALLPAUL is offline
post #6 of 10 Old 10-29-2008, 03:16 PM
Postwhore with an 04
bcm0018's Avatar
I dropped a couple screws and a tiny block of wood (don't ask) while putting headers on my mustang and never found them until recently when I had the motor out. They were there for over two years. The wood was nice and burnt from exhaust heat.
bcm0018 is offline
post #7 of 10 Old 10-29-2008, 04:44 PM
Supraman78's Avatar
Images: 11
That sux....I hate dropping little screws like that. Too many places to look. but make sure it's not in the tire when you rolled it out in the sun!
05 ZX-10R Green *SOLD* - Champs Frame Sliders, Swingarm Spools; Clear Alternatives Integrated Taillight; Clear Euro Signals; H7 Silverstars ; 1/5th Throttle Mod; Ivan's Block Off Plates; Hyperpro Steering Damper; OEM Solo Seat Cowl; Hindle Ti High Mount Exhaust shortened 4 in; SuperLED green running lights, LEDMods.net Green Speedo; GIPro gear indicator w/ TRE
Supraman78 is offline
post #8 of 10 Old 10-30-2008, 03:59 PM
Jazzmaster71's Avatar
screw in a hay stack?
05- ZX6R
06- ZX10R
08- ZX10R
10- S1000RR M-sport, ABS/DTC, Alarm, HP shifter.
Jazzmaster71 is offline
post #9 of 10 Old 10-31-2008, 06:18 PM
afskypilot's Avatar
I did this same thing and found the screw in the shock spring, on the front side where it was out of site.
afskypilot is offline
post #10 of 10 Old 10-31-2008, 06:35 PM
nickalltogether's Avatar
Every time I work on my bike or car I either A) Lose a fastener of some kind, or B) Get it back together and have a fastener left over with no apparent home. My theory is that if I take my bike apart enough times, it will actually hold itself together with no fasteners for assistance.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
The few that screw it up for us all Ninja187 The Out House 17 04-30-2007 03:33 AM
Damnit! BigDally The Out House 27 01-31-2007 07:00 AM
Screw goodiemo Performance and Tech 7 01-15-2007 10:56 PM
Damnit!!!!!!! ninjamaster6-10 ZX-14 Discussion 3 01-03-2007 08:05 AM
Screw me barryblanken The Out House 9 10-05-2005 07:01 PM
