drop in pistons? - Kawasaki ZX-10R.net
post #1 of 20 Old 01-06-2010, 06:43 PM Thread Starter
tone.r's Avatar
drop in pistons?
drop in piston's yes or no? pro's and con's
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 20 Old 01-06-2010, 06:45 PM
All show and all go 10r
JLG0987's Avatar
This like a drop off daycare lol.
JLG0987 is offline
post #3 of 20 Old 01-06-2010, 06:47 PM Thread Starter
tone.r's Avatar
what lol
Tone.R {checkmate}
tone.r is offline
post #4 of 20 Old 01-06-2010, 06:53 PM
beenthere's Avatar
Ok lets see if we can find out what your trying to do? 1) You had some extra money and didn't know what to do with it? 2) You need pistons so you thought drop in pistons sounded like they would work good in case you later want to try some drop in cams? 3) You want more compression? 4) You like the idea of new pistons and didn't want to bore your cylinders? 5) You over heard some one mention them and you thought you would sound cool if you repeated it....ONLINE?
beenthere is offline
post #5 of 20 Old 01-06-2010, 07:30 PM
Speed Freak
garth285's Avatar
tone unless your going bigger bore I'd stay with stock pistons, the JE's are 13.5:1 but you can easily achieve that with decking the cyl head... we actually have quite a bit or room to lower the deck on these motors so you can get some very good compression in her. The JE's advantages might be they are maybe slightly lighter or as light as the stock pistons....
I ran a 40 shot of nitrous on a stock piston motor for over a year or so and never had one problem, its all in the set up....
unless your going to upgrade to a 2 or 3mm pistons kit I'd stick with stock and deck the head
garth285 is offline
post #6 of 20 Old 01-06-2010, 07:56 PM
beenthere's Avatar
I'm not a fan of drop in pistons for raising compression. They usually have a less refined "crown" inhibiting flame travel-not good. I have seen drop ins out weigh the stock slugs, the motor then wastes energy overcoming the increased inertia born of a heavier recipricating part. Occassionally they will have more material above the compression ring decreasing heat shedding properties. Compression (all other things being equal) will be more efficient in getting the wheel turning (torque) but will not neccessarily compliment high rpm horsepower. I will go out on a limb hear and say if its a street motor a slight bump in cr combined with a slightly better cam would really wake it up and for that street motor that has to live with the rigors of street riding, I'm using stock pistons with a thin head gasket or take the manufactoring variables out of the squish band by milling the cylinder deck. If its a dedicated 1/4 mile engine (without class engine mod restrictions) I suppose a little further with cam and cr would make it really get down the strip. And if it is the 1/4 mile engine you are thinking about then I would look into some .080" over, 14:1 Je's.......
post #7 of 20 Old 01-06-2010, 08:17 PM
Originally Posted by beenthere View Post
i'm not a fan of drop in pistons for raising compression. They usually have a less refined "crown" inhibiting flame travel-not good. I have seen drop ins out weigh the stock slugs, the motor then wastes energy overcoming the increased inertia born of a heavier recipricating part. Occassionally they will have more material above the compression ring decreasing heat shedding properties. Compression (all other things being equal) will be more efficient in getting the wheel turning (torque) but will not neccessarily compliment high rpm horsepower. I will go out on a limb hear and say if its a street motor a slight bump in cr combined with a slightly better cam would really wake it up and for that street motor that has to live with the rigors of street riding, i'm using stock pistons with a thin head gasket or take the manufactoring variables out of the squish band by milling the cylinder deck. If its a dedicated 1/4 mile engine (without class engine mod restrictions) i suppose a little further with cam and cr would make it really get down the strip. And if it is the 1/4 mile engine you are thinking about then i would look into some .080" over, 14:1 je's.......
Superacer is offline
post #8 of 20 Old 01-07-2010, 10:19 AM Thread Starter
tone.r's Avatar
Thanks guys for the info, I was asking because if i stay stock bore a guy told me he got some dropin's pistons cheep, there close to the price of the rings.
LOL i DONT just got money to give away thats why i ask for info thanks guy's for yall input.
Tone.R {checkmate}
tone.r is offline
post #9 of 20 Old 01-07-2010, 10:27 AM
Speed Freak
garth285's Avatar
its only $45 bucks to deck the head and 20 for a thin head gasket ;-)
garth285 is offline
post #10 of 20 Old 01-07-2010, 10:35 AM Thread Starter
tone.r's Avatar
can't beat that
Tone.R {checkmate}
tone.r is offline
Drop in the clamps Onequickzx10r Strip 22 08-15-2009 08:16 PM
1'' drop gordotastic The ZX-10R 0 03-25-2009 09:23 AM
07 10R Stretch and Drop brian90505 The ZX-10R 5 03-02-2009 03:32 AM
Drop Links kaeyou77 Vendors deals 1 03-16-2007 02:31 PM
Front drop, with new tires? Rembrant Performance and Tech 41 02-26-2006 09:20 PM
