Drag racers step inside - Kawasaki ZX-10R.net
post #1 of 18 Old 05-12-2013, 12:40 PM Thread Starter
Slow10r's Avatar
Ok, i have been having horrible luck with clutches.. i mean every track day i burn one up in a couple passes, or even on the street they are not lasting me shit. I upgraded to a cycle concepts clutch with stronger springs... still no luck... Only thing i can think of as this point is the oil i am running in the bike. I run mobil 1 full synthetic. I ran motul on my old zx10r and my zx9r with out a single problem ever with a clutch with alot more passes. This bike i have only ran mobil 1 and have had the clutch pulled at least 10 times.. what all do you guys think?
2012 Zx10r- [email protected]
Past Bikes
2011 Zx10r- Bolt Ons
2006 Zx10r- [email protected] 170hp 86tq
2005 Zx10r-9.46 at 145- 158hp 81tq
2009 Zx10r- 10.1 at 140mph 154hp 69tq.. R.I.P. 9-11-11
1998 Zx9r- 10.9 at 129
Slow10r is offline
post #2 of 18 Old 05-12-2013, 01:04 PM
zx racer's Avatar
ive had nothin but good luck with dwayne dragpak both stretch and swb and i run shell rotella synthetic and its lasted me 2yrs but recently started slipin but i will be orderin another dragpak here shortly bc thats the only clutch beside oem thats lasted worth shit. you could change the oil man and see if that help but one thing i did notice with dwayne clutch is you gota keep the cable adjusted alot more often are it will burn up in no time.
05 ZX-10R SWB.
zx racer is offline
post #3 of 18 Old 05-12-2013, 01:08 PM Thread Starter
Slow10r's Avatar
I have one mile on this new oil I change it every 1000 milesI adjust the clutch all the time.. goin motul I guess. .. calling dwayne tomorrow for his input
Past Bikes
Slow10r is offline
post #4 of 18 Old 05-12-2013, 08:05 PM
PatrickG's Avatar
Images: 15
Do you habe any videos of your passes? It would help understand what is going on.
Also.. what is getting worn out? Steels warping or fibers burning up? Have any pictures of the last one.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #5 of 18 Old 05-12-2013, 08:11 PM
thundercoupe9's Avatar
http://youtu.be/jLabL2-_aUM
He's on the magma red bike..................3 pass his clutch gave up the ghost, and my drag pak has been in my bike for 2 years now
thundercoupe9 is offline
post #6 of 18 Old 05-13-2013, 11:26 AM Thread Starter
Slow10r's Avatar
just the steels are burning up, fibers look great.. bike cut a 1.54 60 one of those passes, i think a low 1.6 the next then the last pass i spun real bad, then clutch gave out.. calling cycle concepts in a little bit
Past Bikes
Slow10r is offline
post #7 of 18 Old 05-13-2013, 02:07 PM
zx racer's Avatar
thats exactly how mine look lol. i wouldve thought the fibers would look like crap but they still look good. im actually thinking about reusing them and just pickin up new set of steels.
05 ZX-10R SWB.
zx racer is offline
post #8 of 18 Old 05-13-2013, 02:09 PM Thread Starter
Slow10r's Avatar
talked to cycle concepts, he said i dont have close to the spring pressure needed for my weight with my set up, he said also to run motul oil. He is sending me some different springs, motul oil and all new steels.. just hope its all here by before thursday so i can get it together for kc2k13
Past Bikes
Slow10r is offline
post #9 of 18 Old 05-13-2013, 03:15 PM
PatrickG's Avatar
Images: 15
I made up this "little" video about the different types of springs out there.
PatrickG is offline
post #10 of 18 Old 05-13-2013, 04:59 PM
08-13 Zx10r Brock's & stock clutch spring comparison - YouTube
Great video
High 9's low 10's.. step inside... I like saki Strip 120 05-07-2010 05:12 AM
step inside.... I like saki The Out House 13 04-06-2009 07:27 AM
FL/GA/AL Drag Racers Inside!!! Patrick Strip 0 12-16-2008 10:22 AM
Drag seat for Big Butt Drag racers bluedevil Strip 22 10-16-2007 10:33 PM
05 VS 06 Exhausts ? Experts step inside! 9R to 10R The ZX-10R 3 03-04-2007 10:24 PM
