Does this sound bogus? - Kawasaki ZX-10R.net
post #1 of 6 Old 12-16-2009, 04:42 PM Thread Starter
ZX-10R enthusiast
dudewhrsmybike's Avatar
A buddy of mine was telling me he poured some brake fluid in his fork seals to swell the seal up so it would stop leaking, he let it sit for about a week and drained it out, put new fork oil in there, and was good to go. He bought the seals but never replaced them because this method worked out for him. The bike has 40,000 miles on the stock seals and he hasn't had any issues other than the first leak and he's ridden a lot since then.
Anybody ever heard of this?
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #2 of 6 Old 12-16-2009, 04:45 PM
motomike's Avatar
real good possiblity.it's been known to put tranny fluid in power steering too.
lead,follow or get out of the way !
motomike is offline
post #3 of 6 Old 12-16-2009, 05:26 PM
kawboy10's Avatar
Hmmm not a good thing here is a little test you can do yourself put some brake fluid in a tray put in any old rubber part let it soak a couple days it will swell up like huge but in turn the fluid will make the rubber turn to jelly and break apart after that....well you know the end result....but thats just from what ive seen ...ever seen the result when you accidentaly put oil in your brake fluid ...seals swell up brakes stick on ....just my 2 cents...and have been a mechanic for 20+years ...read may be a quick fix but is your life worth it?...i've done lots of forks factory seals are money well spent fork oil takes tremendous heat its always good to change every couple years or sooner depending on miles ridden of course...hope this helps...
kawboy10 is offline
post #4 of 6 Old 12-16-2009, 05:45 PM
sam_b03's Avatar
I have heard of a guy pouring a little brake fluid in an automatic transmission that was slipping. He claimed it works and that is wasn't a foolproof fix. It was more of a way to keep it limping while you saved the money to the rebuild or a new trans. But it would go for quite a while.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #5 of 6 Old 12-16-2009, 05:54 PM Thread Starter
ZX-10R enthusiast
Just thought I'd ask, maybe worth a shot. I'm really not looking forward to getting the seal replaced again:headshake
post #6 of 6 Old 12-17-2009, 09:47 AM
sweetride10r's Avatar
sounds like it might have worked but at 40k why not just replace them?????
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
Racefit Sound CRAZY B General Motorcycle Discussions 12 03-12-2008 09:16 PM
sound off! rocketracermike The Out House 32 01-02-2007 12:12 AM
Buzzing Sound Stopped - Now a new soundwhat is this sound zx10x2 The ZX-10R 2 06-21-2006 12:12 AM
What's that sound zx10x2 The ZX-10R 28 04-08-2006 09:51 AM
Weird sound!!!! KWAK10R The ZX-10R 2 04-23-2004 09:19 PM
