Do I need a PC3 for my slip on? - Kawasaki ZX-10R.net
post #1 of 52 Old 01-25-2005, 03:43 AM Thread Starter
RMK
ok, ordering a slip on.. do i need a PCIII? i'm thinking probably going with an Area P. any advice on that?
RMK is offline
post #2 of 52 Old 01-25-2005, 03:55 AM
12RPilot's Avatar
Images: 11
My advice is you can't go wrong with Area P. As for a PCIII, you can get along without one. There are alot of maps out there for a bike with only a slip on, in case you do want a Power Commander, however.
12RPilot is offline
post #3 of 52 Old 01-25-2005, 04:01 AM Thread Starter
RMK
anyone have the area P extreme can? the shorty? i thought i saw a pic earlier, but wondering how loud is that really? i'm not looking for obnoxious.. don't need another reason to get pulled over..
area p over an akro?
RMK is offline
post #4 of 52 Old 01-25-2005, 07:21 AM
miykl has one....send him a pm and he'll be more than informative
MAVRIK is offline
post #5 of 52 Old 01-25-2005, 08:03 AM
It's likely you'll get more (harmless) popping on deceleration after fitting your slip-on. Removing the goose helps a lot, as does adding a PC. I usually do all three at once, at a time when I need to remove the tank anyway (checking the plugs, for example).
Cryptoman is offline
post #6 of 52 Old 01-25-2005, 09:48 AM
Andy's Avatar
Images: 25
I have a Akra slip on and no pc. No problem with drivability, in fact I don't think it affected it at all.
I probablly will end up getting one in the future though.
Andy is offline
post #7 of 52 Old 01-25-2005, 10:09 AM
MIA Post Whore
miykl's Avatar
I have the Area P and really like it. The service from Kerry and Kenny is great and they are quick to respond to any questions. They felt there was no need for any adjustments to the fuel curve. I ran mine w/o a pc for about 2k miles with no problems. Capping the air injection will get rid of most of the popping. When i installed the pc I used a downloaded map and drivability was improved slightly. IMO not enough to make one manditory. As for sound levels, IMO, it's just right. No where near D&D loud. Just good sound. Leave the exhuast valve in place and you can be stealth through neiborhoods, then out on the road it screams.
miykl is offline
post #8 of 52 Old 02-13-2005, 10:17 AM
GREENDEL's Avatar
RMK - I dont think you HAVE TO put on a PCIII because the original mapping on the ECU is so rich - your not hurting anything. But if you want the bike to run noticeably better with better midrange and top end the PC3 is the way to go. There is a thread that I started about the huge improvement I got with a PC3 and a Dan Kyle map (free). So answering your question - Do you have to??? NO.... Is it a good idea if you want performance??? YES
GREENDEL is offline
post #9 of 52 Old 02-14-2005, 09:27 PM
Andy's Avatar
Images: 25
This isn't the original name to this thread, I changed it so that the seemingly millions of people that have asked this question might find the answer that they're looking for here.
This is the response I was looking for too. A slip on without a pc3 won't hurt the drivability of your bike. But a PC with or without a slip on will show marked improvement.
Andy is offline
post #10 of 52 Old 02-28-2005, 10:32 PM
beenthere's Avatar
Is the PCIII the same as the USB? Recently in our area the local dyno jet dyno has updated to "auto tuning link map building"---o2 analysis with computer aided map compensation. It is rumored by alot of the locals that this works and is paying big hp dividens, but you gotta use a USB box. Fact or fiction?--what you guys think?
beenthere is offline
Gauging Interest - Akrapovic Slip On Ara Parts, Gear and Accessories 10 11-29-2004 11:43 PM
Aakrapovic Ti slip on with carbon hanger Chaz Parts, Gear and Accessories 13 11-20-2004 12:01 PM
Decisions,decisions dragnfly Performance and Tech 33 11-17-2004 03:17 PM
PC3 maps for Akrap Slip ons ? Finatic-1 The ZX-10R 2 06-04-2004 07:48 PM
Muzzy slip on PCIIIusb map miykl The ZX-10R 5 05-30-2004 05:16 PM
