DIY Servo Eliminator - Kawasaki ZX-10R.net
post #1 of 17 Old 11-16-2008, 09:57 PM Thread Starter
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Well.. I have seen a lot of people with great electronics/electrical skills and they have done/created their own speedohealer, gear indicator, tre, etc.. etc..
Anyone done a servo eliminator yet?
Ivan has one but $110 ?
I dont need it really since I still have a lot of space in my trunk.
But, im just curious.
Lucky10R is offline
post #2 of 17 Old 11-16-2008, 10:04 PM
Addiction_V's Avatar
Images: 9
Send a message via AIM to Addiction_V
i need it, but im a cheap guy. Really good spot for a PC.
Addiction_V is offline
post #3 of 17 Old 11-16-2008, 10:07 PM
Postwhore with an 04
bcm0018's Avatar
Hey guys. Here is a thread about something that might work. It was for taking off the cables so I don't know if it will work for removing it all together cause I didn't look through it very closely since I have Ivans servo eliminator but it might help.
https://zx-10r.net/forum/showthread.p...highlight=tape
bcm0018 is offline
post #4 of 17 Old 11-16-2008, 10:11 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Hey guys check this out, this is for the 04-05, seems no one has got the word out, no need for the 110$ servo eliminator, simply remove one pin from the harness.
http://www.racetaylormade.com/tmpage...fitZX10-R.html
"from instructions: To prevent a warning light appearing on the dash now that the exhaust valve has been removed it will be necessary to remove a pin from the ECU. Disconnect the larger of the two connectors and from the back with the release tab facing up identify the pin on the far R/H side, second row down with a brown and /red wire (see diagram). On one side of the front of the connector are two white tabs, on the opposite side is a single white tab. Push in the single white tab; the two white tabs on the opposite side will push out. Pull the brown and red wire out of the back of the connector and the pin will come with it. Push the two white tabs back into place to lock the remaining pins. Wrap some electrical tape around the pin and tape it to the wiring harness. Re-connect harness to the ECU. "
9R to 10R is offline
post #5 of 17 Old 11-16-2008, 10:37 PM
I've herd removeing causes comp. to run bike in safe mode or limp mode due to falt (FI light). It doesn't seem like this wire pin removel mod would prevent this. IDK. just my non tech $.02
10man04 is offline
post #6 of 17 Old 11-16-2008, 11:02 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Removing the pin, only bypases the servo fault signal, your FI light will still function for any other problem, like normal, and you will not be in Limp home mode, from what I understand anyway. I still have my servo installed, just removed the cables. I see no real reason to remove the servo.
post #7 of 17 Old 11-17-2008, 07:54 AM
ninja44's Avatar
OG I think a lot of people want to do this mod so they can use that area for a PC or some other fueling unit. The 08 has next to nothing in the trunk area and that is a perfect spot for it.
Sean
08 10R Pearl Wildfire Orange
Akra slip on W/Link Pipe, Ohlins R&T Forks, Ohlins 46PRXLS, Attack Rearsets, Guhl ECU Reflash, Ivan's Block Offs, Pazzo Levers, Goodridge Carbo Brake Lines, Vesrah RJL Pads, Riflemans 1/5 Throttle Insert, R & G Sliders & Engine Guards, Puig Z Screen, Puig Hugger, Evotech 1/4 turn gas cap
ninja44 is offline
post #8 of 17 Old 11-17-2008, 11:12 PM Thread Starter
Lucky10R's Avatar
Images: 19
Like I said in the first post, I DO NOT need that space yet.
I have an AKra Full System and my cables are already out,
I just wanna know if someone has come up with an eliminator that is cheaper than Ivans.
Lucky10R is offline
post #9 of 17 Old 11-17-2008, 11:13 PM Thread Starter
Lucky10R's Avatar
Images: 19
I have seen some do it. But is there a 100% way to make sure nothing else gets messed up when you pull the pin out ?
Lucky10R is offline
post #10 of 17 Old 11-17-2008, 11:45 PM
plasticbaby's Avatar
can anybody explain what exactly the "safe mode" will doing?does it control the fuel mapping or timing,or both of them?
plasticbaby is offline
Anyone do the Servo Eliminator mod? SAkI The ZX-10R 58 01-22-2011 03:36 PM
Ivans Servo Eliminator... Big Poppah Performance and Tech 15 04-22-2009 08:39 PM
Exhaust Servo Eliminator KaTooM ZX-6R & ZX-6RR Archives 5 07-25-2007 09:12 PM
anyone want a servo eliminator for cheap? 10 speed The ZX-10R 9 08-11-2005 04:38 PM
Servo Eliminator - cost = $0.00 crispin Performance and Tech 8 07-08-2005 01:04 AM
