difficulty getting into first from neutral - Kawasaki ZX-10R.net
post #1 of 9 Old 06-03-2007, 03:59 AM Thread Starter
when i am in neutral ( at a dead stop) sometimes my ten will not go into first and i have to pump the clutch lever an extra time or two for it to engage into first. bike never slips out of gear even under hard acceleration nor does it miss any shifts. just installed new clutch and that help but did not eliminate the problem. any ideas? thanks paul
pec2903 is offline
post #2 of 9 Old 06-03-2007, 06:59 AM
MIA Ex-Mod
Tread70's Avatar
Sounds like you need to adjust your clutch cable. Check the service manual for the proper way to do this.
Tread
Tread70 is offline
post #3 of 9 Old 06-03-2007, 07:01 AM
inappropriate
hesaves0211's Avatar
Images: 67
if that doesnt work change oil
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #4 of 9 Old 06-03-2007, 07:16 AM
How bad is it? I know all bikes will do that at times when you stop and you have to just move forward a couple of inches or back a few and that solves it. Will it not go into 1st even after you do that?
jessiah1 is offline
post #5 of 9 Old 06-03-2007, 08:38 PM Thread Starter
tried that already but thanks for suggestion.
pec2903 is offline
post #6 of 9 Old 06-03-2007, 08:42 PM Thread Starter
it doesn't do it to often maybe a couple times at most a ride. usually i pump the clutch lever a time or 2 and it always engages after that. it just used to never do.
pec2903 is offline
post #7 of 9 Old 06-03-2007, 08:46 PM Thread Starter
yeah i was going to try that but have only 800 miles on oil but that is with brand new clutch plates. so i'm hoping the oil change will help b/c i'm sure there has to be some break in period for the clutch. thanks bro. for suggestion.
pec2903 is offline
post #8 of 9 Old 06-04-2007, 01:11 AM
norcal10's Avatar
on my 05 i had a clutch pin go out on me. very rare occurance apparently, but it was some pin inside the clutch cover slowly wore down to nothing, and this happened with only 2000 miles on my bike. the first warning sign that something was wrong was exactly what you are experiencing. not to freak you out, but if adjusting the cable doesnt work, i'd have the dealer look at it.
norcal10 is offline
post #9 of 9 Old 06-04-2007, 09:04 AM
FAF
Rent this space
Seems strange that by pumping the clutch would do anything considering it is cable actuated , I presume you soaked the new plates in oil before installation?
Try using a throttle blip before engaging the clutch then drop it into first
FAF is offline
no neutral ,help performancezx10r Performance and Tech 17 01-27-2007 10:20 AM
False neutral sinbad Performance and Tech 11 10-17-2006 11:19 AM
Having difficulty??? TheTruth21 The ZX-10R 6 06-14-2006 07:41 PM
neutral start only 10roller Performance and Tech 10 07-23-2005 02:29 AM
Need help w/ Neutral modiggs The ZX-10R 3 07-13-2004 05:50 AM
