DID 520 w/ Sprockets Install - Any Gotcha's? - Kawasaki ZX-10R.net
post #1 of 12 Old 08-09-2005, 08:55 PM Thread Starter
circusnuts's Avatar
Question DID 520 w/ Sprockets Install - Any Gotcha's?
After dorking around with the stock chain over and over trying to find enough slack to accommodate a newly installed 40T rear sprocket (could only get around 3/4" travel), I broke down and purchased the D.I.D. ERV2 and 17/40 kit from Kyle Racing Engines.
http://kyleusa.com/catalog/520_chain...it_3592325.htm
I will also have access to a D.I.D. all-in-one chain cutting and peen tool (borrowed from a coworker).
Any gotcha's with this install?
Thanks
Phil
Dress for the slide & not the ride
circusnuts is offline
post #2 of 12 Old 08-09-2005, 09:47 PM
Andy's Avatar
Images: 25
The only problem I know of is the hell you'll go through getting off that front sprocket nut. Or will the stock one work with the 520?
Andy is offline
post #3 of 12 Old 08-09-2005, 10:56 PM
yehzx10r's Avatar
I also purchased the same 520 conversion from Dan Kyle with 17/40 sprockets. Haven't done the installation yet. Any advice will also be greatly appreciated.
yehzx10r is offline
post #4 of 12 Old 08-09-2005, 11:10 PM
LordBadly's Avatar
Images: 13
the front sprocket comes rite off with an impact wrench. actually i had more trouble with the rear sprocket nuts with all the damn red loctite they use!! why they dont use the blue i will never understand. good luck man. its not that bad of a job.
LordBadly is offline
post #5 of 12 Old 08-09-2005, 11:18 PM
yehzx10r's Avatar
Does the sprocket nut work with the 520 front sprocket?
yehzx10r is offline
post #6 of 12 Old 08-09-2005, 11:21 PM
LordBadly's Avatar
Images: 13
it did on mine. went on fine just make sure to bend the washer back over so that it doesnt come loose while riding.
post #7 of 12 Old 08-09-2005, 11:29 PM
yehzx10r's Avatar
great! thanks!
yehzx10r is offline
post #8 of 12 Old 08-10-2005, 07:11 AM
sneaky's Avatar
All I gotta ask is why are all of the 10R owners waisting thier time putting 520 on these bikes? Do you all like the idea of ripping teeth off of the sprockets and having to replace them.
My bike came with the 520 on it and I ripped all of the teeth off of a sprocket specialist rear in about 2000 miles. I have a Renthal hard anodized on it now with no probs, but I am also 40 to 50rwhp lower than the 10.
Is the 1/2lb weight savings over the 525 setup worth that much?
sneaky is offline
post #9 of 12 Old 08-10-2005, 07:41 AM Thread Starter
circusnuts's Avatar
In my case, I've found that I "evidently" don't ride hard enough to have stretched the O.E.M. chain to accommodate a new 40T.
Since I have the bike apart and a now apparent bug to try this 17/40 combo, I ordered the Kyle 520 kit.
**Honestly, I have a number of friends who run their bikes hard and have had zero problems with the AFAM and 520 upgrade (no chewed up sprockets, etc.,)
post #10 of 12 Old 08-10-2005, 11:05 AM
Big Daddy's Avatar
Images: 38
When installing any new chain setup make sure to loosen the CS nut prior to removing the old chain otherwise you'll be there for dayz attempting to remove it.
When peening/flaring the mstr link pins alternate back and forth between the two little by little and DO NOT press it on overly tight cuz you'll end up with a link that isn't supple like the others AND most likely split them so avoid this at all costs.
Big Daddy is offline
Drag racing sprockets madav8tr Parts, Gear and Accessories 0 06-26-2005 10:05 PM
Chain and Sprockets ninjazx10r The ZX-10R 19 06-03-2005 09:59 AM
520 conversion Greenhornet Performance and Tech 3 04-21-2005 03:58 PM
520 conversion talk Lyzic Performance and Tech 8 03-23-2005 02:13 PM
[email protected]@K; Contest-win a 520 conversion 16 Tooth CS NWZX10 The ZX-10R 33 02-18-2005 02:28 AM
