Degreeing cams?? - Kawasaki ZX-10R.net
post #1 of 6 Old 09-07-2006, 11:30 PM Thread Starter
Question Degreeing cams??
What exactly is this, do you need adjustable cam sprockets or just adjust them? In what direction? How?
Suzuk1ki11a is offline
post #2 of 6 Old 09-08-2006, 12:58 AM
Speed Freak
garth285's Avatar
its kinda like if its one of those things that if ya have to ask its to complicated but I will tell ya whats done......Basically on the stock cam sprockets there is grooves that u can put the stock nuts in and make the cams adjustable....you need to know exactly what you are doing this because if you dont the engine will not perform well at all and can be fatal to the motor. Stock cams are degreed to 104 or 5 on the intake side and 102 on the exhaust I believe (intake might be higher) But when you use the kawi race intakew cam and degree them to about 106-107/102 you can gain some good power.
Try google searching how to degree cams, its a long complicated process.
garth285 is offline
post #3 of 6 Old 09-08-2006, 01:10 AM
Dragone's Avatar
Images: 11
I agree with garth285. But you can also do a search on the forums to give you an idea on degreeing. It really is not that bad, just do it right the first time.
Dragone is offline
post #4 of 6 Old 09-08-2006, 12:20 PM
Post Whore
1killer1liter's Avatar
Images: 11
DO A SEARCH. This has been talked about extensively.
1killer1liter is offline
post #5 of 6 Old 09-08-2006, 12:34 PM
:iamwithst
Boricua is offline
post #6 of 6 Old 09-08-2006, 01:25 PM
1rocket69's Avatar
Location: Used to be Candler, NC/ Then HELL in Del Rio, Tx/ Now Blaine, WA
1rocket69 is offline
Degreeing cams: Need adjustable cam gears? 41ants Performance and Tech 10 02-10-2006 08:44 AM
Doing the HG and degreeing cams DethsZX10 Performance and Tech 5 02-09-2006 11:24 AM
Degreeing Cams Cody Borders Performance and Tech 4 09-20-2005 11:27 PM
cam degreeing? Floyd Performance and Tech 2 04-12-2005 12:26 PM
Some Basic Theory On Degreeing Cams......... SP8 The ZX-10R 3 03-17-2005 11:18 AM
