decking the head - Kawasaki ZX-10R.net
post #1 of 13 Old 06-25-2010, 01:29 AM Thread Starter
decking the head
i have a 2005 zx 10r full system, bmc, power commander and custom dyno tune. pulled 169.7 at wheel. my friend crashed his 04 ten but had not put in his 13:5 weisco pistons, sold them to me for 250.00 in box. i have 18000 miles still runs great but antz to use pistions, will they cut rilabilty. i go to quicktime motorsports for dyno tuning and the owner said, with those pistons, degreeing cams and porting head i should get 15 to 18 rearwheel wheel gain. said it may run slightly hotter but shouldn't be a reliability problem going from 12:7 to 13:5 pistons. i have had 13 different cycles all companies, the ten has been my favorite and i cant sell this bike as it was my friends who died ( not on bike ) and i cant let her go. i improved my brakes and put in race tech g2 valving with hyperpro springs ( they have a constant velocity spring ) for my weight. feels like i could manage a bit more power with these upgrades. any comments? how bout you garth?
i was going to give the beamer a try but going from 90,000 to 50,000 a year im a bit shy for it, can handle a few grand though. reason is i put 40000 miles on an 04 and 10000 on this one curious to see what happens. plus gives me something to do besides fight with my old lady ovewr winter. thank you paul
pec2903 is offline
post #2 of 13 Old 06-25-2010, 01:52 AM
tasos's Avatar
I have a friend who tried the stock bore wisecos and he actually lost power over stock! I know it sounds strange but it's true. He had ported head+ thin gasket+ webcams.
I suggest leaving the pistons and port/deck the head and get some aftermarket camshafts. You can also deck the head abit. Garth285 can help you out on this.
If you plan to change pistons maybe you should go overbore 2mm (safer) or 3mm.
And if you're opening the engine you will need gaskets, maybe bearings, clutches, springs etc...Engine will be hotter and more noisy. For sure you need Ti retainers and heavier valve springs, even if you go stock bore. The gen1 likes compression but don't go too much!!!
tasos is offline
post #3 of 13 Old 06-25-2010, 11:42 PM
tone.r's Avatar
everything he said, 18hp i dont think so sorry it sound good
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #4 of 13 Old 06-26-2010, 01:06 AM
Dont mess wit White Ninja
abzx10r's Avatar
Sounds like you have a plan, but 18hp is just pushing it
listen to this man, he just did a rebuild
abzx10r is offline
post #5 of 13 Old 06-26-2010, 01:20 AM
Speed Freak
garth285's Avatar
im to drunk to answer now ill poost tomm if i remember :-p
garth285 is offline
post #6 of 13 Old 06-26-2010, 05:13 AM Thread Starter
thank you for responses gentlemen, ur crazy garth alot like the original owner of my bike, he's probably smile down on us now. garth whatdo you suggest about decking the head and getting a little hotter cams ? id like to pick up around 10 to the wheel but don't want to loose characteristics of the power curve. oh i got velocity stacks too basically for the sound but i hear they add a horse or two. had them for my 04 but never used them but would like to try them on this 05
pec2903 is offline
post #7 of 13 Old 06-26-2010, 12:43 PM
Speed Freak
garth285's Avatar
ok after successfully recovering from a slight hang over... I can finally function lol...
ummm my bike had the JE 13.5:1 pistons in it but they were 2mm over... i decked my head .010" which I think brought it roughtly around 14.5:1 compression and I had ZERO piston to valve clearance and I was even running the 9.7mm lift cam and stock exhaust cam...
as for cams idk what you have for cams but if you can find a 04-07 race intake cam snag it what ever the price may be.... if you cant you can run a 08+ race intake as well... stick witht he stock exhaust cam.
dont bother getting custom cams made unless your going with a bigger motor anything more than the race stuff is almost a waste of good money, you could spend that money on going to a 2 or 3mm kit
garth285 is offline
post #8 of 13 Old 06-27-2010, 06:41 AM
gazx10's Avatar
deckingZERO
ZERO ptv. :headshake .010=1pt. :headshake
gazx10 is offline
post #9 of 13 Old 06-28-2010, 10:01 AM
sextaafondo's Avatar
LoL ...
I'd like to believe certain advices are trully given upon own succesfull experience... but its assessment should be strongly considered based on the unconventional setup, and if you don't want to blow your engine up in pieces.
sextaafondo is offline
post #10 of 13 Old 06-28-2010, 04:53 PM
tone.r's Avatar
Tone.R {checkmate}
tone.r is offline
SSB's 04 vs 2010 ZX10R Head to Head hellsrazor The ZX-10R 50 09-02-2011 07:54 AM
06 head on a 05? inginekilla Performance and Tech 2 06-18-2006 07:51 PM
Head to head my 10 & 05 Gixxer 1000 ZXTOM The Out House 28 05-12-2006 10:37 PM
Head to Head- difference? 3 Hp resuscit8u Pictures and Videos 8 08-29-2004 02:28 PM
First competitive head-to-head? Zed The ZX-10R 8 03-05-2004 02:19 AM
