Dead 04 ZX10R No Fault codes - Kawasaki ZX-10R.net
 6Likes
post #1 of 14 Old 09-19-2019, 02:07 PM Thread Starter
whiteryno111's Avatar
Ok so this is my track bike which ran fine and stood for like 4 months before I decided to convert it to street again.
When I was just about finished with all the fairings and stock stuff I decided to fire it up. Well.. Not even a fart!
Used carb cleaner down the TBs, nothing. Fuel pump comes on as normal.
Removed all Bazzaz Zfi stuff thinking something was up with it, same.
Before removing the Bazzaz I noticed there was no rpm info when cranking?? Do they all do that? Dunno
The only change that was made from track to street was the QS that went to my Gen4 and fairings, horn, lights, mirrors..
Went to diag mode, exhaust servo and 2nd flies showing up. Put those back on, zero faults now.
I know cam sensors go on these bikes but it would throw a code right? same for crank sensor?
Who can shed some light on this as I've exhausted pretty much every possibility??
Thanks in advance!
whiteryno111 is offline
post #2 of 14 Old 09-19-2019, 02:17 PM
badassjake's Avatar
start with the crank sensor, follow it back, it may have gotten unplugged
badassjake is offline
post #3 of 14 Old 09-19-2019, 02:22 PM Thread Starter
thanks man, but I've plugged and unplugged that sucker so many times same goes for the cam sensor.
Also should be noted that these sensors don't show up as faults if I disconnect them and try to start the bike.
post #4 of 14 Old 09-20-2019, 04:36 PM Thread Starter
Today I noticed the headlights stay on after I try to start the bike and depress the start button, is that normal? Could the relay box be defective and not powering the ecu?
post #5 of 14 Old 09-23-2019, 09:32 PM
The lights relay is latched on from the start button being pressed. Seems like crank position or cam position. If the ECU thinks the TPS is high/wide open, it won't start.
rocksalt is offline
post #6 of 14 Old 09-24-2019, 08:49 AM
gaz
run into this kind of problem several times on zx10's. appears all at once. always ben the common ground/common positive boxes taped up in wiring harness. two square boxes located in area next to main harness/fuel pump connectors. corossion/burnt wire the common problem.. have to pry apart to check. try twisting/moving the wires in the main harness around these boxes with switch on and watch for any changes. where i would go first.
Sebastian1000 and Boxtradamus like this.
gaz is online now
post #7 of 14 Old 09-24-2019, 10:12 AM Thread Starter
Ok the ECU is getting power and ground.
I also checked that both sensors are producing voltage and resistance is within spec.
what's really puzzling to me, is the fact that Bazzaz cannot get an effective signal from the crank sensor so the RPM is Zero when cranking (Can anyone with bazzaz let me know if they get engine speed when cranking?)
Gaz, you are talking about the two plastic unions yellow and blue correct? they look good and when opened there is a tiny bit of oxidisation but nothing uncommon.
Can't think of anything else other than a ECU fault.
post #8 of 14 Old 10-25-2019, 01:59 PM Thread Starter
Man, still getting nowhere with this thing, replaced crank sensor with used one, used ecu without immo working with EU harness.
Fuel pump kicks in but getting no fuel or spark, checked all 5 five common connector plugs.
Everytime I mess with the bike I age 2 years at a time!!
Please can anyone contribute with something I'm missing?
post #9 of 14 Old 10-26-2019, 12:29 AM
Twistedsocal13's Avatar
completely unplug the bazzaz unit, all of it and hook every thing up as it would be from the factory and let us know what happens
Twistedsocal13 is offline
post #10 of 14 Old 10-26-2019, 12:32 AM
sorry just noticed you have a quickshifter from a gen 4 on it. disconnect that then see if it works. they usually kill either fuel or soar but some work on both. not sure how the gen 4 works or how it will mess with the gen 1 but give it a try. would be pretty shitty if it was causing the issues
