Daytime LEDS not working - Kawasaki ZX-10R.net
post #1 of 10 Old 06-10-2013, 11:42 AM Thread Starter
hey guys, recently swapped out my halogen daytime lights with T10 leds, which i assumed were simply plug and play, however they dont work and i cant for the life of me figure out why, anyone have experience with this? thanks for the help
bostonstrong is offline
post #2 of 10 Old 06-10-2013, 01:12 PM
Supercharged Mod
Polarity? LED only works in one direction. (Some LED assemblies have internal rectifiers so that the assembly can go in either way, but others don't.) Try switching them around.
GoFaster is offline
post #3 of 10 Old 06-10-2013, 01:51 PM Thread Starter
so what your saying is try switching the left side with the right vice versa?
post #4 of 10 Old 06-10-2013, 02:29 PM
Not sure if the headlamp bulb connector is polarised, I don't think it is, why woudl it be. In which case GoFaster is saying to pull the plug off and plug it back in the opposite way around.
Not swap which light the bulb goes in.
trebor27 is offline
post #5 of 10 Old 06-10-2013, 02:46 PM
SkyDork's Avatar
Turn the bulb 180 degrees in the connector itself.
Also, the daytime running lights are not halogens. They are standard incandescent bulbs. The headlights themselves are halogen, but they are different from the little running light bulbs. LEDs only work if you get the polarity correct.
#WordCrimes
SkyDork is offline
post #6 of 10 Old 06-10-2013, 03:09 PM Thread Starter
ok thanks will try and update you all
post #7 of 10 Old 06-11-2013, 11:46 AM Thread Starter
ok so i tried flipping the leds 180 degrees but still no luck, anyone have another idea?
post #8 of 10 Old 06-11-2013, 12:00 PM
SkyDork's Avatar
Test the LEDs separately off the bike by connecting them directly to the battery to verify they are working. Then verify you have power at the connectors to the lights themselves. Also, I'm not exactly sure in your original post what you mean by T10, because those lights are 194s. So you may actually have the wrong lights you're trying to use.
#WordCrimes
SkyDork is offline
post #9 of 10 Old 06-15-2013, 11:46 AM Thread Starter
the equivalent to a 194 is a t10 led, the s im not sure about so it might be that, leds work though when connected to battery so the bulbs are good and the stock bulbs work so the powers there. might just leave it alone with the stock bulbs not worth the headache
post #10 of 10 Old 06-15-2013, 02:25 PM
SkyDork's Avatar
I don't think the T10s is the same as the 194. They make 194s in the LED format to match the bulb socket. If you got T10, I'm pretty sure that's your issue. Likely subtle mating differences. They should plug in and work if the polarity is right. Tons of members have done it.
#WordCrimes
SkyDork is offline
2007 zx10 daytime running lights CEEBREEZY The ZX-10R 41 04-15-2011 09:36 AM
2011 zx10r playtime daytime garth285 Pictures and Videos 12 12-12-2010 11:03 PM
Bike Leds ninjasuz General Motorcycle Discussions 9 03-15-2008 11:32 AM
neons/ LEDS shadowpint General Motorcycle Discussions 6 03-13-2008 05:49 PM
Replacement LEDs Slenver The ZX-10R 8 09-14-2007 10:28 AM
