Datatool Revlight - Kawasaki ZX-10R.net
post #1 of 7 Old 01-07-2006, 04:40 PM Thread Starter
Datatool Revlight
Zx10R has very weak Shift light...like shit
How many of you have experience from Datatool revlight...any photos installed to ZX10R ?
see more
http://www.datatool.co.uk/consumer/p...oduct=revlight
great installation and test video also...
I think this will be my new toy...
lespaul66 is offline
post #2 of 7 Old 01-08-2006, 03:51 AM
Rspec99's Avatar
Images: 11
Datatool shiftlight
Installation is a little tricky because it requires splicing into the stock speedo harness. I got the anodized aluminum case for it as well.
Once programmed it works very well and is easy to see. You can set where the different colored LED's light up, and all of the lights flash when u hit your shift point.
Rspec99 is offline
post #3 of 7 Old 01-08-2006, 06:15 AM Thread Starter
Nice
Nice
I also considered same installation location...but does it fit with standard screen or do I need double buble...
How you have fixed it ? Screw or two sided tape ?
post #4 of 7 Old 01-09-2006, 01:50 AM
Rspec99's Avatar
Images: 11
I have a double bubble on my bike. I am not sure whether the stock windscreen has enough clearance, but I doubt it. I fastened it on with some super strong plastic interlocking velcro and it works perfectly. I didn't want it permanently fixed on there for cleaning and servicability.
A must have on the 10R in my opinion. I don't even look at my factory tach anymore, and it is at perfect eye level view when tucked behind the windscreen.
Rspec99 is offline
post #5 of 7 Old 01-09-2006, 03:24 PM Thread Starter
Rspec99
Could you describe what you did and where are those connections ? Soldering ? and how did you seal up the connections or wires...
Thank You
post #6 of 7 Old 01-09-2006, 04:36 PM
Rspec99's Avatar
Images: 11
Wiring the rev light
Basically you have to partially unwrap the wiring harness (leading to the gauges) and locate three wires. There is absolutely no slack in the wires so snipping and re-attaching is completely out of the question. What I did was CAREFULLY shave off about 1/2" of insulation and solder the datatool connections directly onto the factory wire connections. Then insulate everything with electrical tape or heat shrink. It does create a small bulge where the connector snaps into the gauges, but you probably wouldn't notice unless I told you.
You could probably get away with using the little splicing squares but I am extremely anal (probably from my car stereo days) about electrical connections. Nothing worse than tracking down electrical gremlins due to crappy connectors.
Rspec99 is offline
post #7 of 7 Old 01-15-2006, 02:17 PM
Post Whore
i know this is but where can i find those brake fluid reservoir covers ?
Nick.INF is offline
Revlight Help zixxer The ZX-10R 0 07-13-2005 12:12 PM
Datatool revlight zixxer Parts, Gear and Accessories 0 05-25-2005 07:01 AM
datatool digi gear,where are the wires located? smittyzx10r The ZX-10R 4 04-13-2005 05:38 PM
Revlight Tach Help??? zixxer The ZX-10R 0 04-13-2005 12:56 PM
Revlight Tach zixxer Performance and Tech 0 04-12-2005 11:15 AM
