Gen 2: 2006-2007 Cylinder Head Decking - Kawasaki ZX-10R.net
post #1 of 2 Old 01-06-2015, 03:27 PM Thread Starter
stretched10R's Avatar
I know this is a subject that has been beat to death but want to double check on a couple things before I do it. Just pulled the head off of my 06 and was going to have some minor port work done and have it decked. Was thinking of taking .015" off the head and running the .045 head gasket. Running the stock 08 intake cam and stock 06 exhaust cam. Also was thinking about running the stock intake cam on exhaust side (if worth it). I know ill have to pin it. Stock springs still in the bike so wont be raising the limiter or spraying over a 30 shot on the bike. Also not sure if anyone knows if the gen 4 stock springs are any better. I have a spare set from a previous head I assembled and if there any better then I will reassemble using them. Thanks
Born with that MAD KAW DISEASE!!!!!
stretched10R is offline
post #2 of 2 Old 01-06-2015, 07:05 PM
gazx10's Avatar
.015 deck, .45mm hg good power mods, ptv ok with good degree. gen 4 springs will not work. can shim stk. ex. spring .030 with stk. cam but added lift of 08 cam or int. on ex. will not allow shimming stk gen 2 valve springs due to coil bind. either setup should work good.
gazx10 is offline
Gen 1: cylinder head chanthavong904 Wanted: Buy or Trade 0 04-13-2014 09:57 PM
Gen 3: Cylinder Head BGoodwin22 Parts, Gear and Accessories 8 10-02-2012 05:30 AM
Gen 3: Cylinder head mityaz Parts, Gear and Accessories 1 06-15-2012 04:06 PM
decking the head pec2903 Performance and Tech 12 06-29-2010 05:05 PM
Cylinder head ninja_12r2000 Performance and Tech 4 06-21-2007 07:31 AM
