Gen 2: 2006-2007 Cylinder firing heat - Kawasaki ZX-10R.net
post #1 of 19 Old 11-17-2014, 11:45 AM Thread Starter
Question Cylinder firing heat
Put a heat thermometer on headers and 2 cylinders are firing at 500 heat range and 2 cylinders are at 200 heat range, what would cause this? Is this a sensor problem? Wiring? What is the things to check, I've done resistance check on many sensors already. I have the manual.
Thx
Johnskx125 is offline
post #2 of 19 Old 11-17-2014, 12:13 PM
SkyDork's Avatar
Sounds like a fuel issue. Two of the cylinders are running leaner/richer than the others. Injector issues? Tuning issues? Not real sure, but that's what it sounds like based on that. Those are pretty drastic differences.
#WordCrimes
SkyDork is offline
post #3 of 19 Old 11-17-2014, 12:44 PM Thread Starter
I have swapped out injectors. Put a good set in
post #4 of 19 Old 11-17-2014, 01:05 PM
SkyDork's Avatar
Are you misfiring at all? Have you pulled the plugs to check their condition? That should be the next step I would imagine
#WordCrimes
SkyDork is offline
post #5 of 19 Old 11-17-2014, 02:31 PM
badassjake's Avatar
power commander? they have bias slides for individual cylinder tuning.......
badassjake is offline
post #6 of 19 Old 11-17-2014, 04:56 PM
zx racer's Avatar
Check the coil packs they could be bad.
05 ZX-10R SWB.
zx racer is offline
post #7 of 19 Old 11-17-2014, 05:52 PM
Supercharged Mod
... or throttle body synchronisation.
GoFaster is offline
post #8 of 19 Old 11-17-2014, 11:54 PM Thread Starter
Throttle body sync, idk how to do that. Coils were ohms checked and spark tested, could it be a crank sensor problem? Or cam sensor?
post #9 of 19 Old 11-18-2014, 12:34 AM
bluedevil's Avatar
you need to answer first SkyDorks question...is the bike miss firing at all.
my questions how is the bike running? are you measuring in the same places on the headers up top? I question your meter methods.
did you spray water on all pipes to see if any are cold(not sizzling with water contact)?
What Cylinders are Cold in your opinion?....It may help to troubleshoot the problem you need to answer questions and be as thorough as possible when asking for help especially when we ask questions to help you and you dont answer back.
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #10 of 19 Old 11-18-2014, 12:37 AM
bluedevil's Avatar
Also how is the bike running?......what caused you to think of checking header temps first .....I feel there is a story behind this before you went that route and failed to mention it.
bloo
Gen 2: back firing. AllOut189 The ZX-10R 14 11-03-2012 04:55 PM
Gen 2: Heat issues? Too much radiant heat while riding. maki9389 The ZX-10R 5 06-30-2012 10:31 AM
#1 cylinder not firing Babyboy4896 General Motorcycle Discussions 6 09-15-2011 03:26 PM
Cylinder #3 not firing? Razorboy814 Performance and Tech 5 01-02-2010 10:38 PM
Im firing this B!tch!!!!! 10 speed The Out House 13 02-07-2007 05:05 AM
