Cylinder #3 not firing? - Kawasaki ZX-10R.net
post #1 of 6 Old 01-02-2010, 12:57 PM Thread Starter
Hey Guys,
My 2004 ZX10R has a cylinder thats not firing.
Bike has a PCIII and thats about it for mods.
How do I go about finding the culprit.
I tried laying the plug end to the chassis to see if it was sparking.
The bike appeared to try and start!!!! It spit up out of the TB's with
no fuel tank in place. Very weird. I think the plug fired though.
Should I disconnect the PCIII in hopes that maybe the injector is not
firing?
Give me some tips on how to track down this problem?
On the track, the cylinder will kick in under heavy throttle but at moderate to low throttle, nothing.
Cheers
Bernie
Razorboy814 is offline
post #2 of 6 Old 01-02-2010, 01:20 PM
Supercharged Mod
Disconnect the Power Commander completely and then report back to us.
GoFaster is offline
post #3 of 6 Old 01-02-2010, 04:18 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
And if that does not work you can check your coil with a multimeter, it has a primary and a secondary winding to check. The shop manual gives instructions for this.
And have you changed your plugs before. I had one foul out on me before.
9R to 10R is offline
post #4 of 6 Old 01-02-2010, 04:47 PM
Guilty by association
CP10R's Avatar
i had a plug cause a cylinder to go down too.
General "Mad Dog" Mattis
CP10R is offline
post #5 of 6 Old 01-02-2010, 07:25 PM Thread Starter
It was the plug.
I swapped out 2 and 3 then 2 was dead.
Thanx for the input guys.
Heading out to pick up a set tomorrow.
Cheers
Bernie
post #6 of 6 Old 01-02-2010, 10:38 PM
CP10R's Avatar
great man, im happy it wasnt something serious.
CP10R is offline
Piston not firing or something with fuel destroyerbmx Performance and Tech 3 06-21-2009 11:25 AM
05 10r not firing jasongin00 Performance and Tech 35 07-03-2008 04:09 AM
Need help!! - Bike back firing and FI light is on edouble Performance and Tech 5 05-13-2008 04:27 PM
Im firing this B!tch!!!!! 10 speed The Out House 13 02-07-2007 05:05 AM
back firing anyone? ballzman Performance and Tech 17 07-21-2005 09:35 PM
