Cutting out at high rpm? - Kawasaki ZX-10R.net
post #1 of 5 Old 12-30-2009, 08:45 PM Thread Starter
Hey all,
I've noticed this recently when revving out my 07 ZX10R, so far I've only had it happen in first and second (probably due to the speeds I'd be doing in the higher gears).
It get's to around 10,000rpm and the power will suddenly cut out for a split second, before kicking back in. It's like you're going flat out and then it feels like a sudden grab of the brakes, before it kicks back in again. And flat out in first it scares the sh*t out of ya!
Any ideas?
I'm thinking a loose sensor somewhere on the bike, or even the plugs?
timmy is offline
post #2 of 5 Old 12-30-2009, 09:59 PM
greenman43's Avatar
Images: 33
Possibly vibration-related ? Have a look at the clutch cut-out and sidestand cut-out switches, and make sure the tip-over sensor is mounted correctly.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #3 of 5 Old 12-30-2009, 10:45 PM
Crazi's Avatar
What mods? What have you changed recently?
Also, check out the fuel pump. Normally it starts going bad little by little and you'll notice that it gets lower and lower in the rpm range.
On my 12r, it started at redline and got a little worse every week until I replaced the pump.
05 Z1000 - Traded
05 ZX12R - Stolen
04 ZX10R - Going to be sold soon. New bully on the block!
13 ZX10R - Getting abused...
"It is the mark of an educated mind to be able to entertain a thought without accepting it"
Crazi is offline
post #4 of 5 Old 12-30-2009, 10:51 PM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
I would suspect the fuel pump also.
08 ZX10
ronnulph is offline
post #5 of 5 Old 12-30-2009, 11:24 PM Thread Starter
Hadn't considered the fuel pump. Bikes barely done 7000km's so I'd have to doubt it.
Checked out the side stand switch with the bike running and tried fiddling with it and it didn't appear to have any effect. So maybe not that one?
I'm leaning more towards either spark plugs. Or perhaps crank sensor?
As for mods,
Pipes
PC3
Filter
The rest is all cosmetic.
timmy is offline
Bike cuts out at high rpm 07ZX10RJoe Performance and Tech 8 11-13-2008 08:31 PM
High Rpm Power loss? kawaboy Performance and Tech 28 11-27-2007 02:39 PM
No high rpm fun! grn machine Performance and Tech 9 07-18-2007 08:40 PM
Whinning noise at high rpm? conspiracy Performance and Tech 5 03-08-2007 11:22 PM
WOT motor cutting out at 10,000 rpm Older Guy The ZX-10R 12 05-10-2006 10:18 PM
