Gen 4: 2011-2015 Custom conrod bearings - Kawasaki ZX-10R.net
post #1 of 3 Old 03-18-2016, 01:03 PM Thread Starter
Carlos76's Avatar
Who is making/where to order undersize (custom size) connection rod bearings?
Spun conrod bearing recently and journal was damaged. It can be regrinded to -0.15mm diameter or less. Welding up or buying new crank is expensive.
Carlos76 is offline
post #2 of 3 Old 03-18-2016, 01:19 PM
SkyDork's Avatar
Good luck. I just went through this same ordeal. There are no aftermarket bearings that I could find. I had the crank welded back to spec and used the OEM bearings. You might be able to source some aftermarket connecting rods that have a better selection of bearings, but that will likely be more money than the crank repair.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 03-18-2016, 02:57 PM
Is that exist ?
The bearing from one rod to another couldn't be that different. It goes on the same journal. The width of the bearings could be different but..
Long long time ago 1980's I bought bearing with different specs for a Yamaha connecting rods a company who are in netherlands. But I tried for the zx-10r almost everywhere and no luck.
So if anybody found it just tell me.
ninja_12r2000 is offline
Gen 1: Ran a conrod bearing zuhayr Performance and Tech 1 04-25-2013 07:15 PM
06-07 ZX10R Attack Race Body Custom with Custom Paint & Carbon Kevlar Fuel Cell WSMC712 Parts, Gear and Accessories 4 08-02-2010 11:03 PM
Conrod & crankshaft questions tasos Performance and Tech 13 02-15-2010 08:19 AM
06-07 conrod dimensions greenman43 Performance and Tech 8 11-24-2009 06:00 AM
Custom Headlight (Mild Custom) KidCapri50 Pictures and Videos 1 11-22-2005 09:26 PM
