crankshaft and rod clearance - Kawasaki ZX-10R.net
post #1 of 4 Old 12-27-2009, 05:46 PM Thread Starter
clutch master's Avatar
I got 04 ZX-10 motor with a spun #2 rod bearing. I got crank and another set of rods that im going to replace the damaged stuff with; however, I'm having trouble finding the right sized plasticgage for the specified crank/rod clearance sizes. Why is this, or am I doing or reading something wrong? I have the following plastigage sizes: Blue(.102-.229mm), the Red(.051-.152mm), and Green(.025-.076mm). The specified bearing crank clearances are from (1.491mm-1.503mm). Has anyone else gone through this before?
The clutch is your friend
clutch master is offline
post #2 of 4 Old 12-27-2009, 06:23 PM
sweetride10r's Avatar
your rod bearing clearance should be between .030-.060mm with a service limit of .10mm
your main bearing clearance should be .010-.034 with a service limit of .060mm
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #3 of 4 Old 12-27-2009, 06:34 PM
Supercharged Mod
What you are calling the "clearance" appears to be the total thickness of the insert. What you are looking for is the clearance with the insert installed.
P.S. I'd strongly suggest going by the markings on the crank and cases to pick the bearing inserts, and using the plastigage only to check that you didn't make a major foul-up.
GoFaster is offline
post #4 of 4 Old 12-27-2009, 06:53 PM Thread Starter
Wow, man I didnt go far enough in my manual. I appreciate it guys, just had a case of the dumb-ass.
WTB: 04/05 Crankshaft clutch master Wanted: Buy or Trade 1 12-20-2009 06:23 PM
Crankshaft repairs GoFaster Performance and Tech 6 11-05-2009 05:36 PM
06-07 crankshaft $120 shipped dsabat Parts, Gear and Accessories 4 03-19-2009 08:21 PM
06 zx10 needs crankshaft TX06'10r The ZX-10R 12 11-18-2006 07:30 PM
crankshaft splatmaster ZX11 Discussion 6 03-16-2006 10:09 PM
