Crankcase vent hose - Kawasaki ZX-10R.net
post #1 of 15 Old 12-21-2005, 09:25 PM Thread Starter
Crankcase vent hose
Any benefit to plugging the airbox and running the crankcase vent hose directly to the KLEEN air valve for a bit of "vacuum assist" with crankcase pressure?
Mal
'12 ZX-14R
'12 ZX-10R
65+ and medicated
zx9rmal is offline
post #2 of 15 Old 12-21-2005, 09:45 PM
MIA Post Whore
miykl's Avatar
guess I get say it first, "do a search". Commonly know as the pair valve mod. ..or something like that.
I'm plugged my airbox, but am running a K&N crank case filter. KLEEN system blocked off too.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #3 of 15 Old 12-21-2005, 10:23 PM
It would make sense to me to just remove the crankcase vent from the air box like miykl said. You will gain positive pressure in the airbox and you keep ram air pressure from entering your crankcase, thus letting your crankcase "breathe" better. I don't know if their is a check valve in the crankcase vent or not.
green 10r, Akro EVO 2, Hyperpro rsc, tre, pcIII, Puig DB, K&N, Purvision HIDs, Speedohealer, GONE
08 Ducati Hypermotard S GONE
08 Kawi Concours 14, Area P full sys, PCV, Flies out
speedfreak is offline
post #4 of 15 Old 12-21-2005, 10:26 PM
I've heard that a slightly pressurized crankcase improves piston ring sealing.
I was reading it in on of the picture captions for a Suzuki GP bike.
JodyH is offline
post #5 of 15 Old 12-22-2005, 07:09 AM
sneaky's Avatar
Pulling a vacuum on the crankcase will aid in ring sealing, but you are not going to see it with the KLEEN valve on the 10. It just does not pull enough of a vacuum to be able to do this.
Most race teams that do this, ie nascar, indy, and maybe the drag racers are using a dedicated vacuum pump plumbed thru the pcv syystem. I ahve yet to see a true vacuum system on any of the major bikes in any form of racing to do this yet.
I would much rather get rid of the extra crap and make the engine bay cleaner than deal with the crap from the KLEEN valve. Someone had a dyno graph with before and after runs with this mod and it does absolutely nothing for power on the 10.
sneaky is offline
post #6 of 15 Old 12-22-2005, 09:32 AM
morrisjl2's Avatar
I think I will have to agree that there will be almost no gains to doing this on the 10. I did this mod on my 12 back a few years back
while I was visiting the 12.org site and a few guys on there said it gained between one and two HP.
morrisjl2 is offline
post #7 of 15 Old 12-22-2005, 03:36 PM
Yea, after I thought about my post above, I remembered the Suzuki GP bike had a vacuum line connected to the oil fill cap. For some reason I had pressurizing on the brain.
The Suzuki definately had a dedicated crankcase vacuum line.
JodyH is offline
post #8 of 15 Old 12-22-2005, 07:37 PM
MIA Ex-Mod
Tread70's Avatar
NHRA Pro stock motorcyclyes use a dedicated vacuum pump and they pull somewhere around 20-30 in. of vacuum. I don't think the Kleen mod will make a difference but it don't hurt either. Here is a pic of the main pump that the NHRA PS Bikes use and just FWIW the pump is $2000 or was it $2200 but with the lightweight motor I know is $2700.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #9 of 15 Old 12-22-2005, 07:42 PM
So aside form the vacuum pump idea, is there a benefit from sealing the airbox up? I don't mean the ram air, just the crankcase vent hole.
post #10 of 15 Old 12-22-2005, 07:52 PM
MIA Ex-Mod
Tread70's Avatar
I dont think their is any real benefit except that the air isn't being put into the crankcase. I can only assume that the crankcase is supposed to vent into the airbox whereas to burn up the air from the crankcase (ie: fumes from unspent fuel and oil im guessing) This will be done for the emissions. I also will go as far to say that it will probably benefit from removing it from the airbox but if you go that far you may as well hook it to the Kleen ports on top of the valve cover. If you don't do that and just remove it from the airbox you do need to add a crankcase filter so it doesn't suck in dirt and grime from the road.
Tread
Tread70 is offline
FREE HP??? more opinions on this thread please!(second post) STREETFIGHTER50 Performance and Tech 34 10-23-2005 11:05 AM
Holes in my crankcase?? youlose Performance and Tech 14 10-05-2005 06:52 PM
WTF...Vent thread... Thundercleez The Out House 1 05-12-2005 08:18 PM
Watch Your Coolant Hose Routing........ SP8 Performance and Tech 7 05-06-2005 07:12 AM
check this out (dnwhoop02) tberd Performance and Tech 90 10-29-2004 04:02 AM
