crank and basket code? - Kawasaki ZX-10R.net
post #1 of 2 Old 01-24-2010, 06:58 PM Thread Starter
zx-sik-r's Avatar
what is the diff between the diff codes?i just bought another engine and the code is diff on the gear on the basket versus the one i had....one is a d and the other a c?
zx-sik-r is offline
post #2 of 2 Old 01-24-2010, 07:49 PM
Supercharged Mod
They are meant to be matched sets. The shop manual explains which pieces work with which other parts. If you do not properly match them, the clearances between the gear teeth will not be correct, and that's bad.
GoFaster is offline
Clutch Basket JWALK187 Performance and Tech 37 11-28-2009 08:40 PM
06/07 ZX-10 clutch basket ?? WRECKSHOP The ZX-10R 0 05-26-2009 05:14 PM
ZX-10 billet basket redline659 Parts, Gear and Accessories 7 02-26-2009 05:02 PM
clutch basket and hubs pec2903 Wanted: Buy or Trade 1 03-22-2007 10:56 PM
Bike FI light is on, checked code - need help figuring which code SpeedyCorky Performance and Tech 6 12-28-2005 02:51 PM
