a couple of questions?? - Kawasaki ZX-10R.net
post #1 of 3 Old 08-11-2008, 01:04 AM Thread Starter
codyc_13's Avatar
hey guy i have a couple of questions, first off where is a good place to order a set of stiff ass clutch springs, second is there anyway to tune a bike without a power commander, third does anyone have a good cheap power commander for a 06 zx-10, foruth is what is the proper stack height for the clutch on an 06, and last how the heck do you launch this thing at the track without it bogging, im stretched 7 over gear -1 +2 and an air shifter its 60' desent then bogs and gets a horrible 330'. thanks
codyc_13 is offline
post #2 of 3 Old 08-11-2008, 05:00 PM Thread Starter
codyc_13's Avatar
nothing guys?
codyc_13 is offline
post #3 of 3 Old 08-11-2008, 05:10 PM
You should be able to use shims to stiffen up your stock springs with not problems. Second, yes you can tune the bike yourself with whats called juice box, or the bazzaz system (that will run you some money though) juice box is a bit cheaper the the power commander from what I understand. You should be able to find a power commander for about 150 used on here or on ebay. And as for the bogging down, should be reving from 7-8.5k, the engine is going to bog no matter what unless your tires are free spinning its going to catch and bog. The higher the RPM the less bog, but also the higher the RPM more chance of your tire not catching. Hope this helps.
maineiac1008 is offline
Just a couple questions wanaride23 The ZX-10R 3 06-11-2007 01:17 PM
i have a couple of questions desrat369 Performance and Tech 7 10-21-2006 09:09 PM
Couple questions... GRKZX10R The ZX-10R 10 05-08-2006 06:57 PM
I want to buy a ZX 10-I have a couple of questions Phil C The ZX-10R 22 11-04-2005 09:25 PM
Couple Questions reckless1 The ZX-10R 18 09-06-2005 08:22 AM
