couple o' questions - Kawasaki ZX-10R.net
post #1 of 9 Old 03-26-2010, 07:55 PM Thread Starter
phillip.beaudry's Avatar
Question couple o' questions
i seem to remember reading that a speedo healer cancels out the gear indicator on an 08 10r, also, can i do +2 with the stock chain and stock front sprocket?
phillip.beaudry is offline
post #2 of 9 Old 03-26-2010, 07:57 PM Thread Starter
i meant to ask is it true that it cancels out the gear indicator
post #3 of 9 Old 03-26-2010, 08:16 PM
RDLYN13000's Avatar
Images: 38
not sure about the speedo healer canceling a gear indicator, but yes you can go +2 in the rear with a stock chain and you might as well go -1 on the front while you are at it...
RDLYN13000 is offline
post #4 of 9 Old 03-26-2010, 08:18 PM Thread Starter
i was thinking of doing that, but thought i might try -1/stock, or stock/+2 first. reading some of the stuff on here it might end up being too muchh for me. i guess we will see
post #5 of 9 Old 03-26-2010, 08:19 PM
RDLYN13000's Avatar
Images: 38
well in case you didnt know -1 is about the same as +3 in the rear
post #6 of 9 Old 03-26-2010, 08:21 PM Thread Starter
yeah, but i dont know much about this kind of stuff, and everyone seemes to do -1/+2 for some reason. is one better than the other?
post #7 of 9 Old 03-26-2010, 08:25 PM
Quick10's Avatar
The speedo heeler does not interfere with the gear indicator.
Quick10 is offline
post #8 of 9 Old 03-26-2010, 08:29 PM Thread Starter
sweet. thank you
post #9 of 9 Old 03-26-2010, 08:33 PM
bluedevil's Avatar
:iamwithst It accepts signals from the speed sensor and converts the pulses to show the right Speed when programed right in the Speedohealer the the guage reads the pulses and coverts it to the proper display on your gauge.
bloo
bluedevil is offline
New Here, Couple Questions bmaynard06 The ZX-10R 19 05-10-2009 11:42 PM
a couple of questions?? codyc_13 Performance and Tech 2 08-11-2008 06:10 PM
i have a couple of questions desrat369 Performance and Tech 7 10-21-2006 10:09 PM
Couple questions... GRKZX10R The ZX-10R 10 05-08-2006 07:57 PM
Couple Questions reckless1 The ZX-10R 18 09-06-2005 09:22 AM
