counter sprocket and wheel bearings - Kawasaki ZX-10R.net
post #1 of 7 Old 03-22-2006, 11:23 AM Thread Starter
getting ready to change these, is there anything special i should know(besides the other post by BD on here), i know i need a 27mm deep socket for sprocket,(6 point or 12 point work better), torque spec of front and rear axles is 81ft. lbs. what about countershaft nut and any other nuts that need torqued. by the way the prices of these bearings Big Daddy discussed has went up to about 14 to 15 dollars each now. and Dean at Bearingworks will know which ones u need. what tools work best for removing these bearings? any other help would be appreciated
04ZX10 is offline
post #2 of 7 Old 03-22-2006, 11:48 AM
Big Daddy's Avatar
Images: 38
sure blame the price increase on me
i'm not sure if i addressed what tools i used, in any case there's only a couple of ways and one of which requires some 'special' tools costing a fair amount of dosh or cheese if you will and the other was the less expensive way BUT just as effective.
A 2lb hammer & punch......I purchased a 12" tapered punch with a flat nose that i inserted through one end and once close to the bearing on the other end you'll need to push / tap the bearing spacer (be gentle its aluminum and will gouge easily) to one side to allow access to the bearings inner race and begin striking the punch and work the entire inner race so that it pushes the bearing out evenly / straight. Once thats done removing the opposite bearing is rather easy and can actually be removed with a socket & extension however the socket must be the exact size of the inner race and begin the bangin caveman technique.
side note: heat could also be used to make the job easier but not too much.
Big Daddy is offline
post #3 of 7 Old 03-22-2006, 12:08 PM
MIA Post Whore
miykl's Avatar
I ended up throwing in the towel and letting the dealer knock out the old bearings. at no charge! saaaaaweet!
2011 Ninja 1K street
2004 636 track
miykl is offline
post #4 of 7 Old 03-22-2006, 12:10 PM
Big Daddy's Avatar
Images: 38
why a man of your astute coonass stature shoul'da been able to handle a lill chore like this huh??!!
post #5 of 7 Old 03-22-2006, 12:13 PM
MIA Post Whore
miykl's Avatar
didn't have a long enough punch ta get the job done.
...ahhhh sheeott... Now here come the jokes...
2004 636 track
miykl is offline
post #6 of 7 Old 03-22-2006, 12:27 PM
latdrop is offline
post #7 of 7 Old 03-22-2006, 01:32 PM
1bad7's Avatar
Images: 13
OK I'll bite.
Did she say that to you or was it just that obvious. j/k
1bad7 is offline
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
FS: 2004 ZX-10R rear wheel + cush drive/rotor SuicideMachine Parts, Gear and Accessories 6 08-28-2005 11:37 AM
45T sprocket spoon Parts, Gear and Accessories 0 05-22-2005 03:38 PM
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
