Counter Sprocket Replacement Question - Kawasaki ZX-10R.net
post #1 of 11 Old 03-22-2006, 04:23 PM Thread Starter
dsuperhawk's Avatar
I have a 05' ZX-10R with just under 4000 miles on it and was thinking of swapping out the 17 tooth counter sprocket with a 16 tooth counter sprocket.
Does anyone think it is too late to do this swap since my chain already has 4000 miles of wear ?
Thanks-
dsuperhawk is offline
post #2 of 11 Old 03-22-2006, 04:27 PM
Post Whore
id get a new chain.... if you want
Nick.INF is offline
post #3 of 11 Old 03-22-2006, 04:29 PM
KaTooM's Avatar
I would buy a good 520 chain coversion kit, and lose some spining weight at the same time. I think the stocker is a 525 if I'm not mistaken, which is huge chain, so I doubt you have streached it much in 4000 miles, The worst that can happen is you will wear the new sprocket a little quicker.
KaTooM is offline
post #4 of 11 Old 03-22-2006, 04:29 PM
MIA Post Whore
miykl's Avatar
It'll be fine.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #5 of 11 Old 03-22-2006, 05:49 PM Thread Starter
dsuperhawk's Avatar
Originally Posted by KaTooM
I would buy a good 520 chain coversion kit, and lose some spining weight at the same time. I think the stocker is a 530 if I'm not mistaken, which is huge chain, so I doubt you have streached it much in 4000 miles, The worst that can happen is you will wear the new sprocket a little quicker.
The 10 comes with a 525 chain and it seems to be stretching more than the 530 that came on my old RC51. Could be the extra ponies I suppose. I'm more afraid of the new sprocket imposing more wear on the old chain if that makes any sense.
Thanks-
post #6 of 11 Old 03-22-2006, 05:51 PM
mach_man_187's Avatar
Go with the 520 conversion....I did and the difference is awesome....I also went up 2 on the rear procket and opted for the Aluminum sprocket instead of the steel one......
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #7 of 11 Old 03-22-2006, 05:52 PM
Big Daddy's Avatar
Images: 38
Thanks-
This is another one of those personal choices for sure, i know i wouldn't with 4k but if your funds aren't such to replace the entire setup at once then ok. The OEM chain is a 525 series so make sure the sprocket is compatable.
Big Daddy is offline
post #8 of 11 Old 03-22-2006, 05:54 PM
Post Whore
Older Guy's Avatar
Originally Posted by miykl
It'll be fine.
:iamwithst
I did mine after the first 2,000 - 4,000 miles and the stock chain lasted up to 15,000 before it died. Same with the second chain too...
Older Guy is offline
post #9 of 11 Old 03-22-2006, 06:06 PM Thread Starter
dsuperhawk's Avatar
Yeah, I've been eying an AFAM/ERV3 conversion but I figured for 25 bucks I could try out a new ratio. Besides I like the way the OEM counter sprocket dampens out the chain vibrations.
post #10 of 11 Old 03-22-2006, 06:22 PM
lunitk's Avatar
I was just about to say, it's only twenty five bucks; if it wears out prematurely who gives a shit. I would get the 520, my $.02
lunitk is offline
Front Sprocket Question IcePick06 Performance and Tech 18 12-17-2005 07:49 PM
Chain/ sprocket question VegasZX10R Performance and Tech 50 08-13-2005 10:40 AM
Sprocket question dr_wookiee Performance and Tech 21 08-05-2005 11:10 AM
Installing 16 tooth counter shaft sprocket rickv Performance and Tech 3 04-21-2005 09:33 PM
Changing counter shaft sprocket realestateguy The ZX-10R 6 10-24-2004 12:47 PM
