Could do with some help :) Exhaust wise.. - Kawasaki ZX-10R.net
post #1 of 23 Old 11-01-2007, 03:56 PM Thread Starter
Spliffyaid's Avatar
I have just bought an Akropovic Evo full race system for my bike (ZX10R 06)
I have a couple of questions for anyone in the know
Emmision sensors (mid pipe/before the cat)
How do i remove these, is it simply a case of unscrewing them and removing them and unplugging the sensors from the loom? if so, will this give me any fault lights?
Exhaust Servo
Located under the seat. Opperates on cables to the section just after the cat. Can i just remove all this stuff and again have no FE lights or anything come on?
Feedback appreciated
__________________
Spliffyaid is offline
post #2 of 23 Old 11-01-2007, 04:54 PM
FAF
Rent this space
You need to disconnect the cables from the servo and leave it plugged in, and if you have an O2 sensor , you will need to buy the eliminator kit for it, or weld an O2 bung in the new exhaust and use the sensor ,if it doesnt come with one already in the pipe.
FAF is offline
post #3 of 23 Old 11-01-2007, 05:16 PM Thread Starter
Spliffyaid's Avatar
With all due respect, i aint welding nuffin onto a full race Akropovic system :)
But, your other points make sense and thank you, remove everything but the servo...............
**Edit**
Sorry misread your post........I dont "think" there is anywhere for the 02 sensors to go on the full race acro system (dont get it till Saturday) hence can i just take them off and not suffer with any error lights comng on the dash?
post #4 of 23 Old 11-01-2007, 06:11 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Not sure about 06, but my 04 Evo System has the bung already there.
Make sure you do not touch the sensors when you have them out, the oil from your skin can ruin the sensor.
9R to 10R is offline
post #5 of 23 Old 11-02-2007, 02:56 AM Thread Starter
Spliffyaid's Avatar
post #6 of 23 Old 11-02-2007, 04:25 AM
bkkninja's Avatar
Well I had the full race akra and it does come with a thread hole in each pipe for you to screw in the O2 sensors. I be surprised if it comes without. If so just buy 2 dynojet eliminators and plug it right into your harness. you will need these if you plan on racing and is finicky about your fuel map, as the original sensors will tend to lean it out, but only within a certain rpm range. Exhaust servo as mentioned above.
bkkninja is offline
post #7 of 23 Old 11-02-2007, 04:30 AM Thread Starter
Spliffyaid's Avatar
Cheers, :)
Just have to wait for Saturday i guess :) Not long.............Its Christmas come early for me
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
4 day Track Day at Catalunya in April to try it all out
post #8 of 23 Old 11-02-2007, 04:35 AM
Originally Posted by Spliffyaid View Post
Cheers, :)
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
Euhm, shouldn't you get this done together with the full system?? Your airflow, fuel mixture, motor management will be all f*cked up if you put in the full system without PCIII, airfilter and dyno the bike with custom mapping!!
Good luck in Catalunya!
yves_0016 is offline
post #9 of 23 Old 11-02-2007, 04:48 AM
bkkninja's Avatar
Cheers, :)
Left to go.........
PC3
BMC airfilter
Ohlins rear shock
Front fork work
Dyno'ed
Damn you have to wait till April to try out the bike with all your mods on it.:headshake Thats a helluva long time to wait.
bkkninja is offline
post #10 of 23 Old 11-02-2007, 05:00 AM Thread Starter
Spliffyaid's Avatar
Yep, but the bike aint going anywhere till april ..............plenty of time
Yoshimura exhaust? TiForce exhaust? shawnada1 The ZX-10R 8 09-16-2006 03:16 PM
Read & learn...be wise. R1GSXRKILLER The Out House 11 10-10-2005 01:38 PM
