Gen 2: 2006-2007 Correct model Healtech X TRE? - Kawasaki ZX-10R.net
post #1 of 13 Old 06-08-2011, 09:17 PM Thread Starter
Todd10R's Avatar
I am trying to find out which Healtech TRE fits 2007 ZX10R. I cant find any available for 2007 10r online, only 2008+ up?
There is one available locally (K01 model) but when I asked the shop owner if it would fit a 2007 zx10r - shop only said "if it has a white triangle plug it will work". Shop just wants to sell it. I want to buy it, but ONLY IF it is the correct model! The shops "Check for white triangle plug" doesnt do much to instill confidence it is the correct model. Especially since the shop doesnt take returns on electrical products.
I want to be 100% sure Healtech TRE "K01" is in fact for 2007 ZX10R before I buy.
Also can anyone direct me to a reputable on-line seller who may have in stock tre for 2007 zx10r - IF "K01" is NOT in fact the correct model for this bike?
Thank you MUCH in advance for any help!!!
2007 ZX10R 2005 TTR125LE 2000 YZ250
Todd10R is offline
post #2 of 13 Old 06-08-2011, 09:25 PM
bluedevil's Avatar
Use the site Sponsors.
As for the X-TRE maybe you don't now the terminalogy.....do you just want a gear indicator with a TRE? ...X-TRE is for bikes already equipped with a Gear Indicator but will not disable it by installing a TRE......sorry I can't help more but you need to be more specific....here is the website:
http://www.healtech-electronics.com/
bloo
bluedevil is offline
post #3 of 13 Old 06-08-2011, 09:47 PM Thread Starter
Todd10R's Avatar
I only want the timing retard eliminator - no gear indicator. So looking for TRE only. Thanks much bluedevil! My apologies in advance for the confusion. Thank you for the clairification on the difference between the two different models..
Also one other question;
Is there any difference between the Ivans performance TRE or the Healtech TRE in terms of quality, etc. I am guessing they do the exact same thing? Just vary in terms of costs? $114.00 for healtech vs $60.00 for Ivans performance?
I am sold on the TRE concept; I am simply looking to verify correct healtech model for 07 ZX10R & hear reviews if Ivans performance works exactly the same?
Thanks again! You guys/this site have always come through for me. If ever in Oahu, Hawaii pls call me up! Happy to give you local tour of island.
Todd10R is offline
post #4 of 13 Old 06-08-2011, 09:58 PM
Gen2 Ripper
neverendingmods's Avatar
If you go to the link Blue posted which is the part manufacturer, it will give you the correct part#. Than just ask the dealer what part # they have.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 13 Old 06-08-2011, 10:07 PM Thread Starter
Todd10R's Avatar
The Healtech link posted only shows XTRE no TRE.
Todd10R is offline
post #6 of 13 Old 06-08-2011, 10:12 PM
SkyDork's Avatar
The Gen 2 models use the Healtech GIPro with ATRE. It's the combined gear indicator and TRE. The XTRE won't work. You could also go with Ivans TRE if you really don't want the gear indicator.
http://www.calsportbike.com/gipro/
#WordCrimes
SkyDork is offline
post #7 of 13 Old 06-08-2011, 10:13 PM
Gen2 Ripper
Look up what part # you need here. See sidebar for X-TRE w/o indicator.
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
post #8 of 13 Old 06-08-2011, 10:14 PM
bluedevil's Avatar
Originally Posted by Todd10R View Post
I only want the throttle retard eliminator - no gear indicator. So looking for TRE only. Thanks much bluedevil! My apologies in advance for the confusion. Thank you for the clairification on the difference between the two different models..
It's actually called a Timing Retard Eliminator basically a resistor that tells your ECU what gear or if in neutral what map to use...so yeah then you don't need the GiPro or X-TRE(2008 and above) for your year bike year....you need to just a TRE try site sponsors first if not ebay should be easy to get.
bloo
post #9 of 13 Old 06-08-2011, 10:14 PM
Gen2 Ripper
Or just buy the www.ivansperformanceproducts.com Tre
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
post #10 of 13 Old 06-08-2011, 10:27 PM Thread Starter
Todd10R's Avatar
I just found through healtech product advisor the shop was trying to sell me a XTRE (K01!) for 2008 & up. Had a feeling it was not the right item. Just going to get the Ivans. Thanks much all.
Todd10R is offline
Healtech X-TRE for 08-09 ZX10 throttledemon The ZX-10R 69 01-30-2012 12:32 AM
Healtech XTRE cvzx09 Performance and Tech 11 02-07-2011 07:34 PM
Healtech TRE Luiz_Direito Performance and Tech 2 10-20-2010 03:48 PM
Healtech GI-PRO DS series garth285 Performance and Tech 4 11-30-2009 12:24 PM
'08 Healtech X-Tre for sale Candy08 Parts, Gear and Accessories 14 11-12-2009 03:11 PM
