Cooling fan issues!! - Kawasaki ZX-10R.net
post #1 of 2 Old 04-24-2008, 09:46 PM Thread Starter
Cooling fan issues.. anyone ever have a relay go?
Any of you guys have issues with your fan not coming on even though you have voltage to the harness? When I rig the fan to a battery charger bam it cranks up but it's almost as if the harness doesnt give it enough volts to crank it...the harness is definately juiced after about 205-210 degrees...it seems to be low though...does anyone know what kinda volts it should be kicking out?
Thanks guys for any help you can give me....
Stephen
zx10rSteve is offline
post #2 of 2 Old 04-25-2008, 03:01 PM Thread Starter
I believe I could have a bad relay box has anyone ever had thier relay go bad? Perhaps its not making enough volts..maybe a bad diode?
aluminum cooling fan 05 Kawi Vendors deals 0 09-08-2007 02:37 PM
Cooling Fan bkkninja The ZX-10R 0 07-26-2007 05:43 AM
04/05 cooling fan sweetride10r Wanted: Buy or Trade 1 10-12-2006 11:39 AM
Cooling Fan not cutting in chris Performance and Tech 11 09-18-2006 03:25 PM
Radiator cooling fan GreenGoblin Wanted: Buy or Trade 4 08-17-2006 11:27 PM
