coolant change now running hot - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By Stunt4Life
  • 1 Post By RIKKITIK
post #1 of 4 Old 04-19-2015, 12:57 PM Thread Starter
scott22neale's Avatar
Hi team, I changed the coolant on the bike recently, but now the bike seems to be running hot and coolant levels dropping more frequently requiring top up. The hoses are not leaking, head and gasket OK, no discolouration of coolant. I'm wondering if there is an airlock that's pushing it out the overflow? Have checked that but still same issue, worried about it running hot, as it seems to heat up faster than normal. Any ideas?
scott22neale is offline
post #2 of 4 Old 04-19-2015, 01:07 PM
Stunt4Life's Avatar
System likely has a bubble in it and needs burped
White Fang likes this.
Stunt4Life is offline
post #3 of 4 Old 04-19-2015, 11:24 PM
RIKKITIK's Avatar
I usually need to top off the reservoir once or twice after it's been apart. The system "burps" itself, hence the need to restore the reservoir level. More than a couple times would be a concern.
The heating could be too much antifreeze not enough water. I did that to myself last year. Glycol is poor at heat transfer. I had about 60/40 antifreeze/water mix. Bike ran hot, didn't she'd heat very quickly either. I drained it, had so much antifreeze in it, it didn't even feel "wet". Left in what stayed in the motor, refilled the rest with distilled water = problem solved.
RIKKITIK is offline
post #4 of 4 Old 04-20-2015, 07:05 AM Thread Starter
thanks
Thanks for the replies, will take another look at it.
Gen 4: Time for first coolant change davbib General Motorcycle Discussions 6 04-22-2014 03:37 PM
Gen 3: Coolant change gone wrong?!?!? Bigeclipse The ZX-10R 17 05-29-2012 07:07 AM
Coolant Change for 08' ZX-10r sullysZX10r Performance and Tech 5 12-10-2010 02:28 AM
running hot pec2903 Performance and Tech 4 11-13-2006 10:08 AM
Change Coolant @ 600 mile service? IcePick06 The ZX-10R 11 03-13-2006 10:59 AM
