Coolant Change for 08' ZX-10r - Kawasaki ZX-10R.net
post #1 of 6 Old 07-10-2010, 08:54 AM Thread Starter
sullysZX10r's Avatar
I need to drain my coolant and put in 'ice' for my 08' ZX-10r. There is a good thread on here for an 07, and seems like it could be the same, but I wanted to see if anyone had any step by steps for an 08'.
Thanks
RIP 2008 ZX-10R
05' ZX6rr 636
12' ZX-10r
Austin Racing GP2 Slip On, Ivan's Mod, Secondaries Removed, Servo Eliminator, PC5 w/ Custom Map, Hotbodies Smoke Undertail w/ Custom LED, Brembo Master Cylinder RCS 19, Speglier Steel Braided Lines,
sullysZX10r is offline
post #2 of 6 Old 07-10-2010, 09:13 AM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
I just changed my coolant. Take off both lowers. Remove the right upper trim piece (between fork and upper cowl) to reveal the radiator cap. On the left side, following the hose/pipe assembly, remove the 2 clamps on the elbow hose (where it 90* turns into the engine). This will let about 1/2 gallon coolant out. Reconnect the elbow and tighten the clamps. With a long (skinney-neck) funnel, add your wetting agent and coolant (top of the radiator by removing the radiator cap). At this point it might be helpful to have the bike on it's side-stand (while gently sqeezing the lower-left hose) to force any air pockets to the top right. Top-off coolant, reinstall radiator cap, put back on the plastics, and enjoy the ride.
08 ZX10
ronnulph is offline
post #3 of 6 Old 07-10-2010, 09:56 AM
ronnulph's Avatar
To do it by the numbers per the service manual, here ya go;
ID:	131964   Click image for larger version
08 ZX10
ronnulph is offline
post #4 of 6 Old 07-10-2010, 10:05 AM Thread Starter
Ron, you da man!!! Thanks!
RIP 2008 ZX-10R
05' ZX6rr 636
12' ZX-10r
post #5 of 6 Old 11-25-2010, 04:38 AM
Doyz's Avatar
good work, cheers
Doyz is offline
post #6 of 6 Old 12-10-2010, 01:28 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
I know its wayy to late but...
Before you change it,run a 50/50 mix of deionized water and viniger through it a few times..
Then flush lastly with just de ioionized water and them ix yer coolant additive and water..
NEVER USE TAP WATER!!
craig_sez is offline
IDEA about Gear change and Profile tire change Solo-Six Performance and Tech 5 03-26-2010 12:47 PM
Coolant in my oil?!?!?!? zx10chase Performance and Tech 20 10-26-2009 11:02 AM
coolant soxxerms Performance and Tech 23 12-05-2006 12:09 PM
Change Coolant @ 600 mile service? IcePick06 The ZX-10R 11 03-13-2006 09:59 AM
Server Change (DNS Change too) RichTJ99 The Out House 4 04-18-2004 07:43 PM
