Coolant - Kawasaki ZX-10R.net
post #1 of 14 Old 01-05-2010, 11:33 AM Thread Starter
motomike's Avatar
Coolant
what brand of coolant do you run ?i use WATER WETTER and i stay about 10 degrees lower than my brother which uses ENGINE ICE.but WATER WETTER IS NOT AN ANTI-FREEZE.
lead,follow or get out of the way !
motomike is offline
post #2 of 14 Old 01-05-2010, 11:51 AM
modpup's Avatar
I switched my trackbike to engine ice this summer and saw no difference at all in lowering the temp. Never used water wetter, you are right. It is not an antifreeze. I have only used what has came with my bikes. I have always had new bikes and live where it can get to 50 below zero celsius and have never had a problem with my bikes being stored in an unheated car garage.
modpup is offline
post #3 of 14 Old 01-05-2010, 11:53 AM
maser's Avatar
I've used Engine Ice in the past, and currently using WaterWetter. I have had no problems with either product. However, I cannot say that their claims of much lower engine temps are accurate. Still run about the same temps.
Drive it like ya stole it --- keep the rubber side down !
maser is offline
post #4 of 14 Old 01-05-2010, 11:55 AM Thread Starter
motomike's Avatar
i'll have to say there is a difference between mine and my brothers.
motomike is offline
post #5 of 14 Old 01-05-2010, 11:57 AM
beenthere's Avatar
I once used an aftermarket ready mixed motorcycle specific antifreeze and had an occassion to pull the radiator months later due to an exhaust pipe change and discovered the radiator inlet and outlet tubes nearly 50% choked off by corrossion build up. I could also see some of the radiator core passages clogged with the same junk. I will now stick with the motorcycle manufacterers brand of antifreeze. I don't think you get a real advantage by using the "super cooler" fluids, if you have a properly working cooling system that keeps your engine in its correct temperature range, tried and true factory engine coolant might really be the best way to go.
beenthere is offline
post #6 of 14 Old 01-05-2010, 12:06 PM
Send a message via AIM to Cycle Concepts
We have had great success with the Engine Ice in conjuction with Motul's MoCool additive...We saw a drop in engine temps of 15 degrees...this data comes from data downloads from our MoTec ecu's...you guys have to also remember that your temp sensors are not very accurate...there can be a
+/-10 degree variance in your sensor calibration...a high quality hand held temp gun will show you this..If any of you have any questions or concerns ,I'll be glad to help you out..just give me a call..
Cycle Concepts is offline
post #7 of 14 Old 01-05-2010, 12:11 PM
maser's Avatar
^^^^^It wasn't one of the brands listed above, was it?
maser is offline
post #8 of 14 Old 01-05-2010, 12:20 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
I use Supercool. It's the pre-mixed deionized water and water wetter. I heard the Motul stuff is good shit.I guess it runs cooler, but once you get stuck in traffic, it don't matter what you got, only thing helping you is a 2nd fan. Wish I could legally lane split...
Another thing, if your radiator ever leaks onto your front tire while your riding, you'd rather have the watter wetter type stuff on their vs the glycol based coolants. If you've ever felt a tire with antifreeze on it you'll know it's slippery as a mofo.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #9 of 14 Old 01-05-2010, 12:22 PM Thread Starter
motomike's Avatar
i will be installing another fan pretty soon.
motomike is offline
post #10 of 14 Old 01-05-2010, 12:48 PM
Sigman's Avatar
I use water wetter in my Vmax,for sure makes a difference in temp.
Sigman is offline
Best Coolant? turbo10 Performance and Tech 23 08-31-2009 10:12 PM
coolant capacity teamgreen Performance and Tech 3 12-02-2007 03:14 PM
What is this in my coolant? Larry Grogan Performance and Tech 6 09-10-2007 02:59 PM
Coolant ? dean2847 Performance and Tech 12 04-23-2007 10:13 PM
coolant soxxerms Performance and Tech 23 12-05-2006 12:09 PM
