Confused on suspension change - Kawasaki ZX-10R.net
post #1 of 24 Old 08-20-2006, 04:50 PM Thread Starter
kneedragger_13's Avatar
Send a message via Yahoo to kneedragger_13
Ok....Thanks to niklasinorr, I changed my suspension. I added a 5mm spacer to the rear shock and dropped the front 8mm, we didnt have a stand and wanted to drop it at 5mm, when I get a stand will move it to 5mm. I also stiffened the preload to almost full because of my weight. Anywho...the bike turns alot better now. It still is not what I want but closer. What I am really confused over is that I thought making this change would make it harder to wheelie. It is the opposite, front end just wants to rise in 1st and 2nd. Why would this happen?
kneedragger_13 is offline
post #2 of 24 Old 08-20-2006, 05:20 PM
mach_man_187's Avatar
With the rear higher, you can get a better "bite" on acceleration. This will cause more of a shift in weight to the rear and bring the front up easier.
mach_man_187 is offline
post #3 of 24 Old 08-21-2006, 07:41 AM
brian0128's Avatar
The bike is mad that you made such extreme changes to it without setting the sag and it's trying to throw you off.
brian0128 is offline
post #4 of 24 Old 08-21-2006, 11:21 AM
Supercharged Mod
My thoughts are that raising the rear ride height AND lowering the front ride height are too much in combination.
Do you know the steering feel that you are looking for? I want a "neutral" feel - if I set a given lean angle I want it to feel like I could take my hands off the bars and it would keep that lean angle without further input ... no need to hold it down, no need to stop it from leaning too far.
If you are playing with steering geometry and you are using worn or flat-spot-in-middle tires, you are going to be chasing your tail on this one.
GoFaster is offline
post #5 of 24 Old 08-21-2006, 04:21 PM Thread Starter
Yes, I want it to steer like you say, neautral. I have been fighting the steering since I bought it. If I cant get this to turn like I want then I might be getting rid of my 10.
Any help would be greatly appreciated....
post #6 of 24 Old 08-21-2006, 04:22 PM Thread Starter
You are full of Gibber Jabber
post #7 of 24 Old 08-21-2006, 04:29 PM
Big Daddy's Avatar
Images: 38
whats your suited weight that you have near full preload dialed in??
Big Daddy is offline
post #8 of 24 Old 08-21-2006, 04:36 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
+1 and get your sag set first for sure and then go from there
zx10ragentblack is offline
post #9 of 24 Old 08-21-2006, 04:37 PM Thread Starter
Tipping the scales at about 225 right now riding.
post #10 of 24 Old 08-21-2006, 04:55 PM
Big Daddy's Avatar
Images: 38
Mmm dare i say the fork springs need replacing and if your ok with spending $$$ on the 10 so that it performs to your liking then an aftermarket shock is necessary as well.
Confused - Fuel Economy jeech The ZX-10R 39 11-12-2006 11:03 AM
Another change in the AMA The Duke Race and Stunt 0 08-13-2006 08:34 PM
Oil Change Abiagi The Out House 7 07-12-2006 09:19 PM
Still confused what to get ? Big Ten The ZX-10R 21 10-19-2005 11:42 AM
Server Change (DNS Change too) RichTJ99 The Out House 4 04-18-2004 08:43 PM
